Question about Extron Electronics Switching and Transmission System (tps150-1)
E4OD TRANSMISSION LIGHT FLASHING, HARD SHIFTING 1-2 AND 2-3, IT CANT MAKE UP ITS MIND WHAT GEAR IT WANTS TO BEE IN. PUT A USED ONE IN FROM A JUNK YARD AND ITS GUARANTTEED TOO WORK, WOULD IT BE A SENSOR SOMWHERE???
1984 ford bronco not shifting
Make sure vacuum modulator on transmission has vacuum
Mar 13, 2014 | Ford Bronco Cars & Trucks
Gear shifter seems to be stuck in one gear and will not shift
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 12, 2012 | 1993 Saturn SL2
Lincoln LS2000, transmission hesitates to shift from park into any gear. No problems with shifting through gears in regular driving. Is this a major repair? Only 113,000 mi.
Inspection is required.
This will help.
Thanks.
Feb 10, 2012 | 2000 Lincoln LS
Shifting in higher gears
For Automatic transmission problem,Check the list of help links below.click the link below:----Automatic transmission troubleshooting:----
This will help.
Thanks.
Feb 09, 2012 | 2000 Isuzu Rodeo
Shifting solenoids on 2002 Lancer.
This will help.
Thanks.
Feb 08, 2012 | 2002 Mitsubishi Lancer
2000 Pontiac Gran Prix automatic transmission shifting slow
This will help.
Thanks.
Feb 04, 2012 | 2000 Pontiac Grand Prix
My 92 dakota shifts hard from 1st to 2nd gear but does shift to all gears?
This will help.
Thanks.
Feb 03, 2012 | 1992 Dodge Dakota
I have a 94 Ford f150 that drives in first but revs high until it hits 2nd gear then drives normal is my tranny slipping
chances are that you have an E4OD transmission. It a good transmission, however it's electronically controlled (the E, in E4OD). What this means is that many things outside of the transmission itself can cause the transmission to act up. First thing's first... ensure that your fluid level is sufficient. Then, click the link below to read the thread about the E4OD diagnosis process. good luck.
http://fullsizebronco.com/forum/showthread.php?t=122096&highlight=shifting
Jan 28, 2012 | 1994 Ford F150 Styleside Supercab
Has a hard time shifting gears when coming off the
Transmission torque converter gone bad*
Need new transmission.
Jun 29, 2009 | 2001 Ford Windstar
Overdrive off light on shifter flashing.not down shifting though. but when i slow down it down shifts hard into second gear then its fine. help!
the flahing light is a trouble code sent by the transmission.you must count the amount of times it flashes and email me ill let you know what its telling you.keep in mind one of the flashes is gonna last longer then the rest.
poppinwheelies@sbcglobal.net
Feb 26, 2009 | 1994 Ford F150 Styleside Supercab
Computers & Internet Logo
506 people viewed this question
Top Extron Electronics Computers & Internet Experts
David Payne
David Payne
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
