Question about Protron 7" Portable DVD Player
It dosnt read a disc or dvd - Protron 7" Portable DVD Player
    President:
  • 173 Answers
The most common problem that causes a dvd player to not read discs is that the optical reading lens is dirty or the discs themselves are scratched or dirty. You can clean the optical lens in two ways:
1. You can purchase an inexpensive cleaning disc from wal-mart and most other stores that sell electronic products. You would simply follow the instructions on the cleaning disc and put the disc in the player and it will run through it's cleaning cycle as if the disc was a normal disc.
2. You can clean the optical lens manually. You can do this by unplugging and removing all power sources from the machine. You will need a couple of cu-tips and a small amount of rubbing alcohol. Open the player like you are going to insert a disc. You will see the optical lens which looks like the following picture
Take and pour a small amount of the rubbing alcohol into it's cap and lightly dip a cu-tip into the solution. Shake out any excess liquid from the cu-tip and then going in a circular motion, lightly clean the optical lens. Repeat this 3-4 times and then let the alcohol completely air dry. Be very careful to not put any excess pressure on the lens or allow any of the liquid to drip onto any other parts of the player's components. Let dry for 2-3 minutes before reconnecting any power source. Your optical reading lens should now be cleaned.
If however, you insert the disc and it is not spinning up, then the problem could be that the small spindle motor has malfunctioned or dirt or debris is keeping it from functioning properly (using a can of compressed air will usually clean the inside and usually remove the dirt or debris). If the spindle motor has gone out, then it would require replacement. The part itself is around $25-40 dollars, but it would require someone with the technical experience to replace it and the labor would probably be around $50-65 dollars for labor depending on the prices in your area.
The following is a labeled picture and you will be able to see the top of the spindle which the motor is located directly below that.
You can read in my tips and tricks for dvd players "the most common mechanical problems" for a more detailed list of mechanical failures that happen with dvds.
Try cleaning the dvds/cds and the optical reader first and see if that fixes your problem. Feel free to ask if you need any further assistance.
If you do not mind, could you please rate my help. I would greatly appreciate it. Thank You
Posted on Feb 02, 2010
My dvd wont read or run any disc and it dosnt show up on my device list
remove dvd cover,insert a disc and see if disc is spinning,if not replace motor,if still not working replace pickup lazer
Nov 16, 2013 | Computers & Internet
My dvd wont run any disc and my comp.dosnt show the dvd in the device list
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and then DVD , it's normal failure behaviour. Pls rate my solution if I helped.
My 360 console will not read any disc at all.
Chances are your Disc drive has gone out. Unfortunately this is not unheard of, but the only option ahead of you is to contact microsoft and have them replace it. You'll have to ship the 360 to them, they'll fix it and send it back. If it is still under warranty, this will be done either at no cost, or very little cost to you, but regardless it will be cheaper than buying a new console.
Nov 09, 2010 | Microsoft Xbox 360 Console
The Burner does not read the discs.
try a firmware update and then if it still dosnt see the disc make sure if its old to check inside to see if the laser maybe out of set. and or a bad diode laser.
May 27, 2010 | Canon DW 100 DVD-RW Burner
TRying to load fable 2 for the first time, never played it. I know that there is supposed to be an update but it dosnt show and it claims it cant read the disk. I cleaned it and it read, but a bunch of...
I had the same issue with halo wars. Try putting the disc in, turning the system off, then booting up with the disc in the system. Hopefully it works.
Aug 18, 2009 | Microsoft Fable 2 for Xbox 360
Makes sounds'lazer disk ain't working dosnt spin
if this happens with more than one disc, your dvd drive is burnt or about to burn you may have to replace the drive.
May 05, 2009 | Sony PlayStation 2 Slimline Console
Discs
i had the same problem, not much can be done but send it to microsoft. 18004MYXBOX they will send u a box and prepaid shipping and its usually free since microsoft added extended warranties to most xbox 360s
Oct 21, 2008 | Microsoft Xbox 360 Console
Player could not load content
it's the disc or the dvd drive is dirty and needs to be cleaned
Jul 29, 2008 | Microsoft Xbox Console
PC-Drive
it seems that this drive has problems reading dual layer disks but the 8163b dosnt seem to hope this is helpful
May 07, 2008 | Computers & Internet
Zenith ZND400 DVD/VCD/CD PLAYER
its a mechanical problem from the disc tray section.The disc tray dosnt lap well inside,call your tecnician he will know what to do.
Jan 08, 2008 | Zenith XBV442 DVD Player/VCR
Protron 7" Portable DVD Player Logo
161 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
