Question about Acer TravelMate 341T Notebook
No Post and 4 beep codes for ACER Travel Mate 341T
ACER Travel Mate 341T is not posting.No Video.4 Beeps heard.caps lock and num lock LEDs flash for a second and then the beep codes are heard.The Power LEDs stays on till the beeps and then laptop shuts down on its own
  • bublyboy Feb 24, 2008
    Thanks buddy i think i know what to do
The battery is empty
Posted on Aug 04, 2011
  • Haktar Aug 04, 2011
    Charge the Battery
4 beeps = memory fault. most likely a newly inserted and incorrectly seated ram module.
Posted on May 13, 2008
  • 97 Answers
Depending on the BIOS the 4 beeps can be systerm clock failure or memory,,,,,,, I would replace the main memory if this fails it is the motherboard that is faulty
Posted on Feb 21, 2008
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
My PC intel desktop d845grg has 4 frontal leds. When i turn it on it beeps, then only the 1st and the last leds become constantly on and there's no video signal. I've tried a different monitor and...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM modules and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty also check the graphics card socket for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Sep 09, 2011 | Intel D845GVSR Motherboard
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Computer would not post no beeps heard. i have also tried reseating the ram but no go. Please help.
reasons for no post are the bare basics,
Video
Ram
Power
you should remove everything else HD doesnt need to be attached to post. retry the boot. if no post try to force a beep code by removing the ram. if it beeps its video if it doesnt its mobo.
some boards dont require video, so if video isnt present or not working it will post normaly and give you no beep codes (Bios thinks nothings wrong).
if removing everything but video and ram works try reducing power consumption or get a bigger power supply.
Jun 10, 2010 | Computers & Internet
When i turn on my acer travelmate341 the screen has no display and i heard 2 beeps. what could be the problem and how can i fix it or check whats causing it.
if you dont get any msg or charecter while switching on then i guess the motherboard is out...2 beeps denotes no response from Motherboard CMOS/BIOS chip...
if you can see some msg then the LCD screen may be out...
the option is to get the MB changed
May 10, 2010 | Acer TravelMate 341T Notebook
When laptop swiched on,the note book will on but its screen will showing blackned'pl advice me.
this might be a lcd panel problem or video/mobo problem. first try this. kust leave laptop off. make sure ac adapter is plugged in. now press and hold on the Fn key while the laptop is off then press power button. When the laptops startsup then still nothing on the screen just wait for 3 mins then try to check if you will be hearing beeps. if you heard multiple beeps and still nothing on the screen have you lcd panel, lcd cable and inverter replaced.
but if there are no beeps. check the lock leds (num, caps, scroll) check the status which one is lit on. this will help us identify if it is hardware or which hardware.
Mar 26, 2010 | Dell Inspiron 1420 Notebook
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Acer TravelMate 341T Notebook Logo
1,627 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
