Digitech turntable - skipping stylus and arm
Just purchased a Digitech Audio USB turntable, model GE4056. The software has loaded fine and is recording fine, but the stylus and arm are skipping and skating across the vinyl singles. I've tried three different records, which play fine on other turntables - they all do the same thing. Advice welcome.
  • Audio Player... Master
  • 5,259 Answers
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Posted on Feb 02, 2010
I have purchased two ARK IV white elliptical Stylus replacement needles for my turntable and I am not getting the life out of these items, despite very limited play time. Seems like they just wear down...
What's the turntable? Skipping across the record would be a (mal)function of tracking and anti-skating. The recommended tracking force for this stylus os 3.0 grams. I've been out of the vinyl groove for some years now but I remember my Shure M95 tracking in the range of 1-1.5 g. Railroad spikes track at 3.0. Is this for 'scratching' or whatever it is they call that noise?
Apr 27, 2011 | Audio Players & Recorders
The needle seems too light on the record because it continually skips in the "backward" direction. I don't know how to adjust the controls. Thank you.
These are pretty cheap units as far as quality and workmanship go.
The ancient fix is to tape a dime to the arm just above the stylus (needle).
If a dime doesn't work, use a penny.
Apr 09, 2011 | ION Audio Vinyl Recording Turntable
My PL120 turntable purchase new skips often and will hardly work with music played at a loud volume
The first problem could be the stylus needs cleaning. Please shine some light on the stylus ( needle ) and see if it has picked up dirt from the record groove. This will prevent the stylus from tracking the song properly. Clean using a fine brush in the direction in which the stylus passes the record groove i.e from back of the pick up arm to front- NEVER SIDEWAYS.
Next check the counterweight adjustment at the back of the Pick up arm. The tracking force should be between 1.5 to 3 grams depending on the brand of the cartridge. What ever be the chosen weight the antiskating knob should also be set to the same number.
The skipping can also be because of heavy bass vibration traveling up the body of the Turntable.Good turntables have a floating suspension to prevent this. The tuntable platter will be suspended on springs.You can place it on a rubber Matt or move it away from the speakers ,esp: sub woofers.
Apr 06, 2011 | Audio Technica AT-PL120 Turntable
Jukebox makes records skip.
Most skip problems are caused by a worn stylus or not enough pressure being applied to the stylus. This being caused by the weight on the end on the tone arm being off place.
Jun 20, 2010 | Audio Players & Recorders
Arm's Weight
Not by design.
Tracking Force and anti-skate are preset and unfortunately not adjustable in many modern turntables . You want to be cautious with modifying it if only a couple of your records skip.
If you DO decide to try modifying it consder that the tracking force is in the probable range of 2-4 grams. In the old prehistoric days before T'Ts had adustable tracking and antiskate we would place a dime or penny on top of the cartridge shell to assert the stylus into the groove. THAT is a bad idea unless excessive record and stylus wear is unimportant to you.
Is there anything that might contribute to skipping (not level, scratches, warps, environmental vibrations, loud speakers nearby)?
Apr 01, 2010 | Audio Technica AT-PL50 Turntable
Broken stylus arm is it still possible to get another one and is it possible to fit it myself also new stylus needed as well
The stylus should not be a problem. Without knowing the make and model of the turntable, however, there is no way to respond about hte arm. You have listed this question under the Rotel receiver category, can you pelase supply the ,ake and model of the turntable? Also, supply any numbers that appear on the current stylus so I can verify that either the exact one or a similar substitute is available.
Thanks,
Dan
Nov 18, 2009 | Rotel Audio Players & Recorders
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Hi, I have recently purchased a pair of technics 1200 mk2 turntables. One works fine but the other skips, even though I have tried adjusting the height of the arm and adjusting balance etc, no combination...
there may be a weight missing on the arm , look at the other one to see the parts on that arm and make sure they are exactly the same nothing missing , otherwise there may be something wrong with the armitures guide
try tape on a penny then put it on top of the arm and see if it still skips
electech
Oct 31, 2008 | Technics Audio Players & Recorders
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
794 people viewed this question
 Grubhead
Grubhead
