Question about Convair Heating & Cooling
Missing internal Fan Flap for convair plus evaporative air conditioner. purchased from Harvey Norman approximately 2 years ago. It is the flap that closes when the a/c is not operational.
    Problem Solver:
  • 12 Answers
The motor shaft of fan is not rotating some time or continuously. you need to service your motor from where fan get support.
Posted on Feb 02, 2010
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
Free standing Convair Supercool leaks like a sieve! We have no manual. Does the small black hose pipe drain the water from the white pipe at the bottom rear of the unit [ where most of the water is coming...
The water is being generated from humidity inside the air. The air conditioner also acts as a dehumidifier. The black line is the drain. The drain line needs to go to an outside line or to a container to collect the condensated water. With low humidity levels, the water will evaporate back into the air. With high humidity, the water is removed from the air at a higher volume than can evaporate back into the air.
Jan 29, 2011 | Convair Portable Air Conditioner
Open or closed
Keep the flaps open to the required direction. Generally you can not close 100%
May 26, 2010 | Danby DAC6003D Air Conditioner
Air conditioner blower flapper stuck on defrost and not blowing out vents
This flap is controlled by a vacuum operated actuator. Either the actuator is bad, or there is a leaky or missing vacuum hose for it. Or flap is just stuck
Sep 05, 2009 | Heating & Cooling
Looking for a manual for solid fuel heater
Since the unit is only a few years older than I, I'm going to give you the contact info for the states. They might be able to pull up a manual on some micro fisch somewhere. I wish you all the luck on this one. This is the name of the Convair brand company here in the states.
Seeley International (Americas) Corporation Head Office and Pacific Coast/
Southern/Central American Sales
1202 North 54th Avenue,
Building 2, Suite 117
Phoenix AZ 85043
USA
Ph: (602) 353 8066
Fax: (602) 353 8070
E: americasales@seeleyinternational.com
Mar 22, 2009 | Convair Arctic Breeze 1500 Air Conditioner
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn Air broken flap on outside exhaust hood
I have the same problem. How do I get the new outside cover when I don't know a part number?
Dec 07, 2008 | Jenn-Air JXT5830AD Kitchen Hood
My elderly parent purchased a new tosheba fridge 2 months ago. the fridge failed on Tuesday and approximately $150.00 woth of frozen & fridge stock was lost. Today Thursday the fridge is not repaired...
I didn't even know that Toshiba made refrigerators. All major manufacturers nowdays have spoiled food insurance to at least 300 dollars. I would contact customer service at Toshiba and tell them you want the unit fixed within 2 days or you will return the unit for a refund.
Oct 23, 2008 | Refrigerators
Heating & Cooling Logo
56 people viewed this question
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
