Question about Ovens
Pilot wont light , I shorted out the wires off the heat element while cleaning ( I shoulda unplugged it ) It doesn't seem cracked or broke, but could be.What elae could it broke ?
  • 619 Answers
You will have to install new igniter defenitly and maybe even the control valve that the wires go to but do the igniter first. Hope this helps.
Posted on Feb 02, 2010
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element not working
When cleaning the oven you got to be very careful because there's a little piece of copper in the back it looks like a little copper wire with a bare copper wire on it that is usually a thermostat it's on the back wall of the appliance inside the oven now you have a heating element on top and bottom you said that one of them stopped workin now you have a heating element on top and bottom you said that one of them stop working when you were cleaning the oven could you may have hit it moved it enough to disconnect it at the connection that comes out of the back of the oven to the inside of the oven to the element check and see if the two wires coming out of the back of the inside to the element are disconnected usually it's a Phillips head screwdriver now if you broke one of those wires needs to be reattached before you do any kind of work on that element or anything you should always unplug your oven from the wall the electrical outlet unplug it to be safe now if your thermostat which is that wir thermostat which is that wire copper wire looking thing coming out and see me on the back wall of the inside of the oven it's on a clip if you moved or bent that in any way that could also cause you thermostat which is that wire copper wire looking thing coming out and ceiling on the back wall of the inside of the oven it's on a clip if you moved or bent that in any way that could also cause your temperature to be off you really don't want to have to touch that if you don't have to I hope that helped you be safe and good luck
Feb 18, 2018 | Kenmore 47722 / 47724 / 47729 Electric...
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
I used the self cleaning function and now the over wont work. The lights work, but no heat is produced. I get no error messages, any ideas?
might want to check if element has continuity with light-wire-battery technique or VOM (volt ohm meter)...unplugged and element out... then while element is out can plug back in and use VOM to check element receptacle for 220v AC (to see if power coming to element (good to check also since continuity check can be fooled by a break in the nichrome wire within the element where the ends of the break only retract to make a gap when main current is applied)
........If no voltage at recepticle then between their and control switch/temperature selector.
...the full blast current and heat of self cleaning, could have completed the ready to fail point/switch/etc
Aug 09, 2009 | Whirlpool RBS305PR Electric Single Oven
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
51 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
