Question about Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90
My new Dremel 400 series has had plenty of use in the past few weeks. The brushes wore out rather quickly,but I ordered a new set. The problem is the brush doors.I have followed the instructions and found it very difficult to remove the old brushes. I have found it virtually impossible to fit the new ones and have damaged one of the doors. Too much force is required to close the doors as per diagram(for such a delicate part) I need advice on how to do this properly and would like to know how I can obtain online a spare brush door (probably need 2,as I have no faith that this won't happen again. ..Thanks ...Mark.
4 Suggested Answers
SOURCE: dremel 400 xpr stopped working.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
Posted on May 24, 2009
agent91
  • 2100 Answers
SOURCE: new dremel 4000 used very little is missing the
Dremel has all their replacement parts right on the shelf at walmart, brushes, caps, chucks, the works. You found the cap, the brush is a little carbon square attached to a wire with a spring on it. Real simple. Buy a pair and get it fixed up. My favorite tool.
Posted on Jun 25, 2010
puertobori
  • 7733 Answers
SOURCE: I purchased a Dremel Xpr 400 series rotary tool a
Go to Dremel ->LINK. Just be sure to set the parts right.
Posted on Oct 06, 2010
How to install brush spring
There is 2 blue caps on both sides of the Dremel.Just unscrew it with the Dremel wrench and replace the brushed.
Oct 06, 2010 | Dremel 400 Xpr Rotary Tool
It appears that the locking mechanism that is engaged in order to charge out bits has stripped out. No matter how hard I press the button to engage the lock, it always slips when attempting to loosen the...
This can happen if you accidentally depress the spindle locking button while the tool is running -- a common problem since Dremel did not include any type of interlock to prevent it, and the button is right where you'd hold the tool for best control. If that happens, you probably will need to replace the tool or send it to Dremel for repair.
Dec 15, 2017 | Dremel 400 Series Xpr Rotary Tool Kit with...
Motor gets hot very quickly and the brushes are still very good
could be the bearings or the armature rubbing the field. if you had it apart make sure the electrical parts are seated fully.
Apr 18, 2010 | Dremel 400 1/6 120V Xpr Rotory Tool...
I was just using my 400XPR and it stopped running cold. Could I have burned out the motor? There's no smell that would indicate that.
Could be the brushes burned out. Don't panic, they are user replaceable. If you have the user guide it should explain exactly how to do it. If you don't have the guide you'll first need to get a set of replacment brushes from a larger hardware store. Make sure to get brushes for your model. On the side of the tool are black slotted caps that can be unscrewed BE CAREFUL THE SPRINGS UNDER THE SCREW CAP CAN GO FLYING. With the cap removed the old brush will fall out and can be replaced with the new one. 2 brushes, one on each side are needed. The 400XPR is a newer model so if this doen't repair it, there may be a defect in the tool.
Mar 07, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
How to change 400 xpr brushes
I went to Dremel.com and found a parts explosion for this tool and the shunt appears to be connected to the brush holder. It is a little fuzzy on the print. If you go to their site they have a toll free number that you can talk with a tech and they will be glad to help. If I have helped you with the problem would you please rate this response accordingly and thank you.
Aug 15, 2009 | Dremel 400 Xpr Rotary Tool
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Running slower than it originally did
blow out the ducts on the side and if that is not it replace the brushes.
Jun 05, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Dremel 400 xpr stopped working. checked brushes looked ok but replaced with new ones. still not working. tool is still fairly new with only light to medium use.
Mar 31, 2009 | Dremel 400 Xpr Rotary Tool
Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90 Logo
118 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
