Computer Have recently installed new Processor, Motherboard & Ram in a new ATX case. Processor a AMD Sempron LE-1100 Socket AM2, Motherboard a MSI K9MM-V based on K8M800 and VIA VT8237 R Plus chipsets. After assembly, the PC was used for data entry in Excell. Since USB not working I open casing and checked all the wires. Since then PC switches off 1 - 2 secs after pressing on button. Doesn't reach boot stage. Will not start again until mains switched off and then on again. My PC-savvy son & nephew assembled the PC a few days ago when they were here on leave. Won't be back soon. Need urgent help that will be highly appreciated.
  • infofreak Feb 20, 2008
    Thanks Mistyman & Haltech for your suggestions. Will try out and get back with results.
  • infofreak Mar 31, 2008
    Had posted a problem of PC switching off by itself a few secs after pressing On button. The MB, Processor, Ram & Cabinet along with power supply were new. Went back to seller who said the switch was faulty and rectified it. Now the PC is fine. Thanks to all for suggestions.
    Novelist:
    Champion:
  • 231 Answers
Hi, Turn off your machine and unplug it from the power outlet. Make sure you have no static electricity on yourself by earthing yourself to the case. Remove, the CPU make sure no dust is present and re-install it ensuring that it is seated properly.
Do the same with the RAM chips. These 2 areas are the most common cause of boot failure.
Regards mistyman
Posted on Feb 19, 2008
  • 33 Answers
Hi infofreak,
Try to follow these steps one by one.
1. Remove the power supply cable from the hard disk, CD/DVD, floppy drive or any other device you might have.
2. Check the wires that go to your front panel ;pwr sw, reset, hdd led, pwr led, speaker etc. Make sure there are at the correct position.
3. Now turn on your computer, if ok you should see some info on your monitor screen.
4. If ok, you can put back the power cable to hard disk only left the others open. Turn on the computer , if ok then proceed with other device one by one. If something wrong in between then maybe your power supply isn't deliver enough power to your system. Get a larger rating power supply.
5. If step 3 is not ok, then take out the power cable on the motherboard from the power supply. Wait a few seconf and place it back to the connector. Make sure it is securely fit, you should hear a click sound once it is fitted in. Turn on your computer.
If Ok repeat step 4.
6. If still not ok, as step 5 this time take out the CPU.
Try the above steps and see whether they can solve your problem. Good Luck
Download drive
The issue of motherboard drivers is not affected so much by the processor itself as the chipset type/version installed on the motherboard and the operating system you plan to run on it. If you can provide the motherboard manufacturer, its model number and revision, and what operating system you are going to run, we can point you to the correct motherboard drivers.
Nov 07, 2013 | AMD Sempron LE-1100 1.90GHz Processor -...
Software for both board and processor???
If your talking about the drivers for the motherboard, if they didn't come on a CD with the board you will have to go to the AMD site and download them. Use the search for updated drivers option and enter the information it ask for.
Aug 14, 2011 | AMD Sempron LE-1100 1.90GHz Processor -...
I need the sound driver for my AMD SEMPRON LE-1100 1.91Ghz from where i can take it? thankyou
The sound driver for your computer can be downloaded by using the model number of your Computer mainboard, use Google!
The model number of your computer mainboard can be found on you computer mainboard between the PCI, PCI-Express or RAM slots.
So type model number of your computer followed by audio driver into Google!
damnor01
Dec 30, 2010 | AMD Sempron LE-1100 1.90GHz Processor -...
AMD Sempron LE-1100 1.90GHz Processor sound drivers
?? You need the motherboard's / sound card driver, the CPU does not drive it directly. They are board specific.
Jun 19, 2010 | AMD Sempron LE-1100 1.90GHz Processor -...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Can i change my processor? AMD LE-1150 to dualcore or core2duo?
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
Apr 27, 2010 | AMD Sempron LE-1150 2.0GHz Processor -...
I want mother board AMD SEMPRON(tm) PROCESSOR free home edition
That chip should be a Socket AM2 interface, so these mothorboards will be fine, it all depends on how much you want to spend.
Foxconn M61PMV
PC chips A15G
Biostar K8M800MAM2
ABIT NF-M2PV
MSI K9N6PGM2-V
Have a look or ask at your prefered site or shop for Socket AM2 and you will have a much better choice.
Mike
May 10, 2009 | Microsoft Office Professional 2007 Full...
I have lost my motherboard CD, please give me solution for this problem
Go to the motherboard manufacturers website. Click on the support link. Lookup your specific board model #. Download and install the software/drivers pertaining to the operating system you are running. This should give you everything included on the original cd. Hope this helps.
Apr 17, 2009 | AMD Sempron LE-1100 1.90GHz Processor -...
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
