Question about Graco SnugRide - Giselle Infant Car Seat
How many years are car seat good for i have a 2005
On the bottom of mine it has a don't use past date...
Posted on Feb 04, 2010
How to fix error code B223D for Jeep Grand Cherokee with engine 3.7L of year 2005
That is probably a fault with the sensor that detects a person sitting in the seat. That sensor is there so that if no one is in the seat and you have an accident the air bag won't go off. You need to take this to a dealer as it requires special tools to re-calibrate the sensor once it is replaced.
Aug 02, 2016 | 2005 Jeep Grand Cherokee
Where can I get the the hard plastic that is on the back part of a driver and passenger seat in a 2005 g6?
a salvage yard would be best other Pontiac's have the same seat backs that year
Mar 30, 2013 | 2005 Pontiac G6
Seat heaters and electric seats stopped working. Could this be associated with a fuse problem?
check the wiring harness below the seat. The harness includes the power to the driver power seat as well as the seat heaters for both fron seats. My 2003 has a contact issue where it only works when another person puts pressure around the harness and wires (Bad Connection). This happened after 2 years of use with this harness. harness has been replaced 3 times over 7 years
Jan 18, 2011 | 2005 Chevrolet Tahoe
Driver side heated seats keep coming on when they want to, on my 2005 Chevy Suburban Z71. They get really hot. I have found that if you leave the base of the seat on the low seating then the back or lumbar...
The problem could be the drivers seat module.It is under the seat and controls the drivers seat functions.There is a service bulletin for seats that will only work for a few minutes and then shut off by themselves.The fix for this is having the drivers seat module reprogrammed but I don`t know if your problem would fall in this bulletin.Only the dealerships can program these modules.Hope this helps.Good luck.
Feb 04, 2010 | 2005 Chevrolet Suburban
Wheres the battery located on 2005 dts
The battery is under the rear seat on the passengers side.To remove the seat bottom push in and up from the front of the seat.There will be 2 latches.One on the passengers side and one on the drivers side.There is also a seat heater connector on the passengers side so when you pull the seat up make sure and disconnect this connector before removing the seat.You will see the battery once you pull the seat up.Good luck.
Nov 16, 2009 | 2005 Cadillac Deville
How do you install Navigation Disk on 2005 RX330?
You will need to access the back of the vehicle either in the cargo area behind the rear seat or under, the seat... not sure which model year used which location but try behind the seat first.. This will involve removing the liner and the housings underneath it so you are down to the metal of the floor boards
Nov 06, 2009 | 2005 Lexus RX330
Rear middle seat belt in 2005 jeep grand cherokee will not work
take it to your dealer and tell them the problem they should be able to fix/relpace the seat belt
Aug 11, 2009 | 2005 Jeep Grand Cherokee
WHERE IS THE BATTERY?
I believe the Buick body style is the same for the years 2000 to 2005. The battery for my 2000 Buick LeSabre is under the back seat.
Jul 09, 2009 | 2002 Buick LeSabre
Needing an 8th seat
its not design for that sir
Jul 08, 2009 | 2001 Honda Odyssey
Heated seat 2005 Buick Rendezvous
ASE mechanic
sounds like the thermal regulator is not operating properly. and it doesn't hurt to call and see about the warranty!!!
Nov 21, 2008 | 2005 Buick Rendezvous
Graco SnugRide - Giselle Infant Car Seat Logo
162 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
