Question about Indesit W 83
W83t, programme selector knob keeps clicking over clockwise. is it just a faulty switch?
  • Indesit Master
  • 3,463 Answers
No it is not a faulty switch, it is the selector switch going round because of another fault on the washer, it is usually associated with a faulty control module.
Check your handbook and see if there nis a reset point on the selector switch dial, usually marked with one or more solid black dots.
Hope this helps.
Posted on Feb 02, 2010
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
ERROR CODE 61
If you have Zanussi washing mashine
To enter diagnostics:
  1. Switch off the appliance
  2. Press and hold down START/PAUSE and any one of the option buttons simultaneously
  3. Holding down both buttons switch the appliance on by turning the programme selector one position to the right (clockwise)
  4. Continue to hold down the START/PAUSE and option buttons until the LED begins to flash (at least 2 seconds)
In the first selector position, the operation of the buttons and the relative Led's is checked; turning the selector knob clockwise activates the diagnostics cycle for the operation of the various components and displays any alarm conditions.
Apr 21, 2014 | Washing Machines
The input selector switch has a mind of its own and changes when it likes to what it likes. There is a clicking relay sound when it occurs. Is this a faulty relay or a dirty switch. (Sorry about previ
I havd the same issue. u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 04, 2013 | Technics Audio Players & Recorders
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Post the results back to me.
Nov 30, 2012 | Washing Machines
Washer will not start
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
Programme Selector knob keeps turning. - Airston Margherita AB95
turn knob to solid dot then leave it for a little while to reset then turn it onto the desired cycle
Jun 02, 2008 | Washing Machines
Washing Machines Logo
652 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
