Question about Lands Phones
Hi i have a panasonic xyg67160es telephone i can not make eney calls i have cheqed that the man line is ok with an old phone i have lost the instrushions
  • 3 Answers
1. Make certain you are using the correct charging plug in adapter. This can cause serious troubles.
2. Replace the batteries and if no dial tone..........
There is no setup or program that will give the cordless set dial tone once removed from the base.
3. Make sure the cordless you have came with that base.
Let me know if this helps....
There are other things we can check with more info.
Posted on Feb 19, 2008
How do I fix my siemens landline phone?
well lightening does do bad things to telephones . that are always plugged in to electric and phone lines
Feb 25, 2015 | Siemens Gigaset A58H DECT 6.0 Digital...
My panasonic home phone only rings once, it used to ring normally and would also say what number is calling. please help.
We recommend you unplug the Panasonic base unit and make a test call from another number. If the line disconnects after 1 ring then you have either a telephone line problem or another device connected to the telephone line is the problem.
Mar 03, 2014 | Panasonic (KX-TG1032S) Phone
Hi, i have a Panasonic KX-T7730 phone. And i have two telephone lines (Line 1 and Line 2) to receive and make calls. I've inaccidentally pressed something and now Line 1 is not working - I am unable to...
From the idle phone press PROGRAM line 1's button and dial 0 1 STORE. That puts line 1 back under the button.
Press PROGRAM or pick up the handset and set it back down to exit programming.
Carl
Apr 19, 2011 | Panasonic KX-T7730 Corded Phone
We have the panasonic KX-TA 824 with the 3CO x 8ext we have disa on on CO1. We are trying to route the incoming calls to CO2 & CO3 to live the main number available. How can we acomplish this.
By calling the telephone line provider or going into the web interface and using Call Forward Busy to CO2 and CO3. Normally, hunt groups are established by the telco or the "poor man's way" with CF-B.
Carl
Feb 18, 2011 | Panasonic KX-TA824PK Phone
I have a panasonic kx-7630 with two different external phone lines programed. One of these lines was anuled but the telephone still try to call throug this one. How can I do to anulate this line in the...
The line must be deactivated at your telephone system programming, this is normally done by connecting a PC to it with the corresponding management software of Panasonic. You could look for the nearest Panasonic technical support service to do it.
Feb 09, 2011 | Panasonic KX-T7630 Corded Phone
Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
KXTD816 Panasonic telephone - lost phone connection
Good thing. You probably don't need to know. Try powering the system down, and power it back up. Watch the lights as it comes up.
Do you get a solid light on the lower right side of the cabinet? Now see if you can dial intercom to intercom calls. Press one of the line buttons and see if it lights up. If it does, I'd be looking for dial tone at the telco interface. Those are RJ-14 jacks (2 lines per plug).
P.S. The reset button you don't want to press is on the lower right side of the cabinet. If the switch is in the wrong place, you'll trash the memory.
May 31, 2010 | Panasonic Lands Phones
Cannot dial but have dial tone, and they hear me, but I can't hea
I GAVE UP WITH NOT HAVING A PHONE AT HOME THAT WOULD WORK. YUP, I DID IT. I BOUGHT A NEW ONE. NOT ALL THE PROBLEMS ARE FIXED. BUT MOST ARE. AT LEAST I CAN HEAR THE CALLER AND THEY CAN HEAR ME.
Jun 29, 2009 | Panasonic KX-TG5632 Phone
Panasonic KX-TG9341 (purchased 9/10/08)
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Nov 03, 2008 | Panasonic KX-TG1033S Cordless Phone
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Lands Phones Logo
91 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
