Question about Dell E173FP 17" LCD Monitor
Hi. I'm running two monitors off my HP notebook. a Planar and Dell, both 13". The Dell just got vertical lines and is mostly purple. what happened?
  • Dell Master
  • 1,183 Answers
Disconnect the monitor from the back of the laptop . Check if the monitor is still purple in the self test feature check . Or there is a vertical line. If the color and the line is not there in the self test. Check the signal cable for any bent or broken pins. If the same is not the issue .
Check the video card drivers for problems.
Thanks
Proton
Posted on Feb 06, 2010
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
Pink/purple vertical line visible
Anytime you see visible lines running through a display, this is usually an sign of an eminent screen failure. It could stay that way for weeks or the lines could multiply and then it could fail. There is no repair for this, only screen replacement.
Feb 20, 2010 | HP w17e Monitor
Vertical lines on monitor
there is no way to fix monitors on laptops all it could be doene is replace but it its more expensive than to just buy a new one
Oct 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on fixya.com!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
Lines across my screen
if the Hp has lines on it....then...
check the left hinge of you notebook if you feel there is something wrong with it then call HP and tell them the left hinge is bad.....and if lines stay on in bios then they should definitely help you out ....even though if you are out of warranty...they would tell you whether they can help you only after they see the serial no. of the notebook
if dell has lines on it then you can call dell cuz dell gives seperate warranty on monitors
Mar 17, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Vertical Lines in Monitor
Definitely ask HP support. They should be familiar with this wierd problem.
Apr 13, 2008 | HP Pavillion ZV6000 Notebook
Vertical white line in center of monitor
Your monitor may have been cracked somehow...
Try restarting and look to see if the line is there immediately from the start or does it only show up when your operating system (windows/linux) loads?
Regards,
Chester
Jan 11, 2008 | Dell Inspiron 2200 Notebook
Dell E173FP 17" LCD Monitor Logo
155 people viewed this question
Alun Cox
