Question about Zenith SY2551S TV
I can't seem to get the universal remote to the program to the TV. I need the code for a Zenith model no. SY2551S TV so that I can program my Philips Universal remote.
  • reppepv Feb 02, 2010
    Philips Universal Remote: model CL035A
    I tried those codes with no success......I did program the Philips Universal Remote to another one of my TVs and it worked fine using the code search method. What's up.....?
  • 11,896 Answers
Ok, I will need the philips universal remote model number so I can give you exact and correct information.
Posted on Feb 02, 2010
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Feb 02, 2010
    ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
  • Nate Stansfield
    Not all tv's are the same. Even if brand name is same and model is different. Some can have 3 codes, some are 4 codes. I don't use the codes myself. I use the auto search. Pressing tv, the setup, press and hold setup button for 5 full seconds, then continuously press and release the power or channel button until the tv shuts off, as SOON as it shuts off, then press the tv button again to store the code.
    1. Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
    2. Step 2
      Look
      for the "Setup" or "Code Search" button on the Philips remote control.
      Which button your remote has will depend on the exact Philips remote
      control you are using. This button may be a different color or may be
      labeled.
    3. Step 3
      Hold
      either the "Setup" or "Code Search" button for about 10 seconds. If
      your remote has a light, the light should begin blinking. If there is
      no light, you can just count to 10 and then let go of the button.
    4. Step 4
      Press the "TV" button on the remote to program the Philips remote to your television set.
    5. Step 5
      Find
      and press either the "Up" or "Down" channel button on the remote.
      Continue pressing either button until the television channel changes.
      This may take several minutes. Once the channel changes, press the
      "Power" button on the remote to turn off the TV. Your Philips remote
      will now be programmed to your television.
  • Nate Stansfield
    Although the sticker in the battery compartment says CL035A, the model of the remote is actually a SRU 3007
    http://wiki.answers.com/Q/What_are_the_c...
  • Nate Stansfield
    You should be able to setup without codes and have it work just fine.
  • Nate Stansfield
    If you want or ever need a full online manual for this remote, you can see it here:
    http://download.p4c.philips.com/files/s/...
I can't find the code to so I can program my
Here is an online manual. http://www.manualslib.com/manual/334599/Universal-Remote-Urc-R6.html
Sep 29, 2014 | Televison & Video
Need all in one remote urc3021 code for dynex tv
Do you mean a One For All URC-3021 remote? The manual and code lists are available here: http://www.oneforall.com/support/manual . Enter Universal Remote and then the model in the drop down menus. The direct link for the URC-3021 manual is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
The Dynex TVs are usually made by LG/Zenith. You can try the Zenith codes: 0017, 0463, 0178, 0092 .
However, universal remotes are usually limited to having only codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
(the URC-3021 remote manual has a 2004 copyright date.)
Jun 28, 2011 | One For All URC-3021 Remote Control
I have a one for all universal remote model number URC 4330B01 and I need the code to program it to a Zenith tv
To program your Sony Universal Remote control for a Zenith TV try - one by one - the following numbers: 009, 010
Jun 04, 2010 | Televison & Video
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Need remote code for zenith tv model c13a02d
remote code don't go by model, you get a list of codes and you just try them one at a time until one works, here are the most up to date remote codes for a Zenith TV.here are the three digit codes
101, 142, 149, 177, 241, 345.
remember all universal remotes have code search, so if none of these seem to work do the code search function, it is outlined in the user manual of your remote.
Jan 28, 2010 | Zenith C13A02D 13" TV
I need codes
Hi stimmdua,
There are a number of codes for your remote that work with Zenith TV models. They are:
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
Programing a remote
My son-in-law showed me how to pickup the code from the zenith TV, thanks for your concern.
Nov 09, 2008 | RCA 3-Device Universal Remote with...
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Aug 28, 2008 | Zenith C27A24T 27" TV
Televison & Video Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
