Question about HP PSC 1410v All-in-One Printer
I dont know how to setup a wireless printer to my laptop. I have a wireless router and an ethernet cable plugged in, but how do I set it on my computer wirelessly?
  • Marc Laporte Feb 03, 2010
    For the \\Nameofyourpc\PrinterNamehere, where do I find that information? Is all this gonna be on the Wizard program%Pr
  • HP Master
  • 12,061 Answers
Well what you do is, First, install the correct driver for your Printer on the one chosen to be the, "Master" PC, then, connect the Printer to that PC via the USB cable. Then after it is installed & shows up,Go to the setup & in the printers Properties, ensure you set the printer for "Sharing" & Take note of where it "Is" & it's "Name" & "Path". Also ALL your PC's MUST have an INDIVIDUAL NAME and be connected to the SAME "Workgroup". Then from each "Client" you must Install a Printer too. Now on Client, go to, Install a Printer, & run it, when it asks what sort? You identify "Networked Printer" and "Browse" for it. When you find it, simply connect to it and follow any instructions. If you can't find it, enter the name of master pc & printers name... (from the Master install). When you connect follow any instructions Now you are ready to print..
When you look for the printer it will look like this....\\Nameofyourpc\PrinterNamehere
So basically, you have setup a network, with the PC's & a Printer... You have one Master that the Printer is connected to, & all "Others" connect, to the Printer, Through, the Master PC, subsequently it must be ON for it all to function.
There is another way, and that requires a printer with an Ethernet connector, this then, can be simply plugged into a router port & it will show up as a network share, that can be used by anyone else on the network., As such there is no master and no need to have any other PC's powered up for it all to work.
Posted on Feb 02, 2010
  • electronic & computer repair&  servicre
    It will be in the NETWORK NEIGHBORHOOD. Or you would "See" it when you "Browsed" for the Network Printer. Also it will be in the "Properties" of the Printer. Under Connections.
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
How to set up router with a lap top
well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
I DONT KNOW HOW TO PUT MY NETGEAR ROUTER THROUGH MY LAPTOP , SO I CAN HAVE WIRELESS INTERNET ACCESS
u will need RJ45 CABLE (normal ethernet cable, labelled cat5e)
plug one end into laptop network connection other into laptop
login address will be (netgear) details will be under router
http://192.168.1.1pi
or something like that.
login id: admin
password: password
if u cant login then, press reset button back of wireless router, will need to do that with pen or pin?
once logged into the router, use the setup wizard and the the rest is self explanatory.
once setup is dne, with SSID and password, then plug the cable from laptop, in back of the internet modem coming into ur house from ur supplier....and ur ready to surf the web.
find your new wireless network using the laptop and insert the password....
Oct 10, 2010 | NetGear WGR614 Wireless Router
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
How to set up wep security on a linksys router that was already set up with no password it is a linksys wrt54g on lrouter a dsl network
Hi
Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
thanks & rgds
Jul 13, 2010 | Linksys Wireless-G WRT54G Router
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
I am trying to connect my macbook pro 4.1 to a wireless printer. That printer works fine - when on wireless with my wifes windows machine and it works fine if i connect my mac to the printer- just not n a...
IN the case of the Mac what I have had to do in the past was shut down the other laptops and computers, delete the printer program from the Mac and start over. During the setup of the printer make sure nothing is connected to the printer. Only connect what you are instructed to at the appropriate time. It will eventually ask you how you are going to connect to the printer from that particular printer, answer ethernet cable and attach the ethernat cable to the printer from your router, make sure your laptop is connected to the router with an ethernet cable. Always set your computer up to the printer vis a hard line, then onve it is done you can swap over to a wireless setup. Once the setup is complete and a test print is accomplished bia ethernet cable, then disconnect the cable from the laptop to the router. Once you are connected to the network wirelessly, attempt another test page, you have already set the printer up at this point to be your default printing device so the laptop will find the printer on the network and initiate it. You may have to watch close for a pop up window asking to allow the connection or access to the program. Maybe think about dropping the firewall temporarily until the connection is secure.
Nov 29, 2009 | Computers & Internet
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Can I connect this if I don't have a desktop computer
You can connect one of the laptops using an ethernet cable and configure the router.
If you need instructions I can post them here, use "Chat Live Now" or Premium to get yor answer
Let me know if you need further help
ta, HPC
Jan 24, 2009 | NetGear RangeMax WPN824 Wireless Router...
HP PSC 1410v All-in-One Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
