Question about Lexmark X1270 All-In-One InkJet Printer
When checking my ink cartridges they show question
My printer is not printing. I went into the solution center to check and it shows a picture of each of my ink cartridges with a question mark on each one.
    President:
  • Lexmark Master
  • 2,022 Answers
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
I have a brand new HP PSC 1410 and after having to buy a black ink cartridge my printer still doesn't print in colour. The printer came with a preinstalled colour cartridge.
The product software print setting is probably designated as grayscale. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is not selected.
Step 2: Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  • Open the Printer Toolbox . There are two ways to open it:
    • Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and click Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge might be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    Dec 07, 2010 | HP PSC 1410 All-In-One InkJet Printer
    How to check the ink level onC4480 printer
    To check the ink levels from the HP Photosmart Software
    1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
    The Printer Toolbox appears.
    2. Click the Estimated Ink Level tab.
    The estimated ink levels for the print cartridges appear.
    Or
    Print a self-test report
    1. Load A4 unused plain white paper into the input tray.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    The product prints a self-test report, which might indicate the source of the printing problem.
    3. Make sure the test patterns show a complete grid and the thick color lines are complete.
    • If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
    • If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
    • If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
    Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
    All of a sudden my hp 932c printer started printing funny in color. I was printing pictures and the prints came out like a heat resolution type picture. I then got new ink cartridges, it did not fix the...
    quite often inkjet heads will dry up and clog. try a clean heads sequence in the printer properties panel. do this until it prints the clean nozzle page properly. If the ink cartridges have the print head attached to them (some dont) you can dab them on a paper towel with windex or vinegar until they show a nice clean line when dabbed. if you cant get the print heads out , then you just need to continue running the clean nozzel application until it prints the test nozzel job properly. This is the reason I will not buy any more inkjet printers. only Toner based machines. cheers.
    Aug 25, 2010 | HP DeskJet 932c InkJet Printer
    How to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Check ink cartridge
    Your ink cartridges could be dried up or empty, even if they are new.
    Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
    How do you check ink levels
    Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    1. Open the Printer Toolbox . There are two ways to do this:
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
    Nov 23, 2008 | Office Equipment & Supplies
    Ink Level
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.I hope this Solve your issueKhaled
    Oct 21, 2008 | HP PSC 1600 InkJet Printer
    New ink is not printing
    make sure the paper is off the ink cartridges
    Jul 29, 2008 | Canon i9900 InkJet Photo Printer
    Lexmark X1270 All-In-One InkJet Printer Logo
    64 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
