EWorkflow How can I set up eWorkflow designer on a new computer
    Genius:
  • 1,665 Answers
How to connect to PC
Well these are designed for RCA plugs which have not been used on computers for quite some time. It can be done but for the cost and time I would suggest just going to Best Buy or Amazon and buying a new set with 3.5 mm jacks which is standard for now.
Mar 02, 2014 | Philips MMS171 Computer Speakers
I have a bouth a new computer with windows7. I have installed all my 4D Embroidery Extra and 4D Reader Writer. However I am unable to call up designs on my reader writer. Do I have to install a new...
I had a similiar problem, but I have the Designer SE. In Windows 7 there is an option to run it in a compability mode, so I had to set my program to run in XP 32 bit mode for the 4D software to run. I don't know if it will help, but if the software worked in XP, this should do the trick.
Dec 26, 2010 | Husqvarna Designer I
JUST INSTALLED MY ADVANCED LABLE DESIGNER ON A NEW COMPUTER WITH WINDOWS 7 AND WE CANNOT GET IT PRINT MULTIPLE LABELS ANYMORE.
So far, the only solution I have found is the following:
Once theLabel has been designed, click on the Bar Code Button, click on the Data Entrywindow, press the Tab key which will allow more Labels to appear on the IndexWindow to be printed. Click the Tab key to create as many labels are needed toappear on the page to be printed. Note: TheCopies of Each Label setting on the File Print window will not work in Windows7. The Copies ofSets of Labels prints the number of pages desired for that Label.
Nov 24, 2010 | Avanquest My Advanced Label Designer Full...
Got a new computer supports window 7 and sharing with my other computer which is the host and has the printer which is a lexmark 5600-6600 series.. when i go to print it says this incorrect port...
This printer and this software (on your laptop) want to hold hands directly ... not through a proxy. You have solved your own issue ... plug the Lex into the new computer.
Sep 27, 2010 | Office Equipment & Supplies
My HP pavillion, window 7 cannot find the designer
You need to reinstall them, they will be on the communication disk that came with your machine or the 4D software cd if you purchased that.
May 21, 2010 | Husqvarna Designer I
New aspire z5610, doesn't see mouse or keyboard. Unpacked new computer,followed set up instructions and trouble shooter but can't get mouse or keyboard to communicate.Any advice would be appreciated before...
This is a common problem. With our new Aspire Z5610 we pressed the reset button under the keyboard but the problem came back from time to time. To be be honest the design of the Aspire keyboard and mouse is rubbish. Went out and bought a new Advent wireless keyboard and mouse in sleek aluminium design - works a treat and no problems so far. Cost £35 from PC World.
Feb 22, 2010 | Acer Computers & Internet
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
Nov 23, 2008 | Husqvarna Designer I
How do i configure my Barracuda7200.10 AS PRIMARY MASTER
When more than one hard drive is installed on a computer system, each drive competes for control of the computer. To allow both drives to work in harmony on the same computer system, the controlling (or startup) drive is designated the master drive and the other drive is designated the slave drive. You can change this designation. The following procedure applies to any PC-compatible computer.
Instructions Difficulty: Moderately Challenging Things You’ll Need: Step 1 Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set. Step 2To change the designation of a new drive to be a slave drive, skip to step 4. Step 3To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable. Step 4 Check the hard drive documentation or the label on the drive itself for master/slave jumper settings. Step 5Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20). Step 6Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label. Step 7Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.") build_pc_xp2000_maxtor_40gb_jumper_matchup.jpg Set to label on your hard drive. Different on every drive.
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
744 people viewed this question
David Payne
David Payne
