Question about Nintendo Super NES Console
Does on the yellow red and white cable... on the side that plugs into the system does it have a full row of connectors??
  • 85 Answers
No, its like a little rectangle-like cord and ends with the red/yellow/white cord. Hope that helps.
Posted on Feb 17, 2010
I need detailed instructions on how to connect a wii console to an asus vw266h monitor
You need to get another cable for that WII that is for HD. It has 5 connnectors on it. The red and white are the sound, the other three are for the video.
http://www.amazon.com/s?ie=UTF8&keywords=wii%20hd%20cable&page=1&rh=i%3Aaps%2Ck%3Awii%20hd%20cable
Dec 02, 2012 | ASUS VW266H - VW266H 25.5 LCD Monitor -...
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Trying to hookup a dvd player model #DX-DVD2
You need 3 RCA plugs... generally colored red, white, and yellow. on the back of the DVD player plug the yellow to video out, the red to audio out (stereo), and the white to audio out (mono). The other side of them goes to the back of the TV... the yellow video input 1, the red audio (R) input 1, the white Audio (L) input 1. Then take the cable service round coax cable and screw it into the back of the DVD unit where it says Coax. Get another short coax cable and hook to back of the DVD unit on Cable out, and the other side to the back of the TV under cable/vhs. And that"s it! Hope that helps you!
Chuck
Jun 23, 2012 | Dynex DXDVD2 Player
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
Hi, I'm having a bit of trouble setting up our hard drive and playstation 3 up to the plasma as the cords are yellow, red and white but on the back of the plasma they have red white red blue and green and...
The red whit and yellow connectors are for the Component connectors, your cable is for Composite connection - incompatible one to each other.
Your tv also has that yellow red and white connectors somewhere on it - probably on the side. Plug the cable there and respect the color coding or it will not work.
Sep 26, 2010 | Televison & Video
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Im a girl, & i need help hooking up my ps3 to my flatscreen
ok it should all go into your tv ok? and there should be a row of yellow white red or any order (ON THE FRONT). you should look on the back of your tv or side for alot rows of inputs and each row should be for an different input on your tv like input 1 2 3 4 5 6? you follow? so just match the colors up on the back or side of your tv or front do not hook it up to your cable box..........Ahh i see the cable box is using the yellow one well maybe unplug that while your playing or there would prolly be other (RED WHITE YELLOW) on the back of your tv like i said or on the side
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Nintendo Super NES Console Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
