Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
Poulan 2 cycle gas chainsaw 18 inch. Was real busy up in trees and forgot to add Bar oil. It started smoking. i tried to engage saw to rotate chain and it wouldn't move. Added oil and it still won't start.
  • 8 more comments
  • sajwrite Feb 02, 2010
    The engine will not start. I removed chain and inspected it. Adjusted tension and checked the chain brake - all okay. I followed manual instruction for deflooding. Still won't start.
  • sajwrite Feb 03, 2010
    I'll be clear. Oil was added to gas- Inside is not toast- all shiny. Smoke came from chain housing. Not muffler. All cleaned and reinstalled per specs- tension etc. Better?
  • lindsay836
    lindsay836 May 11, 2010
    You probably burned up the bar sprocket. Remove bar and chain, engine should now start. You will have to get a new bar( and maybe chain also) unless you can oil sprocket and free it up.
  • dontbother10
    dontbother10 May 11, 2010
    Chech for spark: Ignition Coil Test by SmallEng.comhttp://www.youtube.com/watch?v=L7WNBDRG4... You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. Inspect the plug when you remove it reply with whether it is wet or not.
  • dontbother10
    Take it to a local saw shop they will tell you it is cooked!
  • dontbother10
    You are not answering the questions I am asking. Look inside the engine! It is toast! Posting the same thinh 3 times is not helping!
  • dontbother10
    The engine got so hot it was smoking? Not the bar and chain? Did you forget to add 2-cycle oil? Do this and reply to me with what you find in the cylinder. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil. · Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears? · Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges? · Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears? Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
  • dontbother10
    What wolld not start? Does the engine run? Is the chain brake dis-engaged? Can the chain be rotated by hand? I think you welded the chain to the bar. Can you remove the bar and chain? Is it a Poulan PP4218? Reply below below with some answers to my questions so I may answer yours.
    Problem Solver:
  • 15 Answers
No bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Posted on Feb 09, 2010
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan cahin saw,18" model. Starts ok. Will not rev up. Choke opens full. Filters clean. Used less than one hour since purchased. Hedley
If I purchased this new, mixed oil with the gas prior to adding it to the tank, and it only worked for hour I'd be standing on the service desk. Take it back. If you forgot to add oil to the fuel they may work out a deal on a reconditioned unit. It costs nothing to ask. HTH
Lou
Oct 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have no fire on my pro 40cc 18 inch. what part
new are used coil is what you need distance between coil and flywheel is the thickness of a business card
Sep 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
459 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
