Question about HP Pavilion dv6000z Notebook
I have a toshiba satellite s505 laptop that can no longer find any wireless conections on the router they are all lostr
    President:
  • HP Master
  • 2,022 Answers
Make sure the wireless adaptor is on and the button is showing wireless light. Just search it for wireless device and put the wep key and use it.
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
I CANT CONECT TO WIRELESS USEING MY TALK TALK ROUTER...IM NOT EVEN SURE IF MY LAPTOP IS WIRELESS ENABLED ITS A TOSHIBA SATELITE PRO..L20
Hi tracie23368... There's a wireless toggle on the front to control to rurn on the onboard Atheros 802.11b/g WLAN module. All you should have to do is push that toggle in the front of your machine to the right or to the left and hold for a few seconds which will turn on the Atheros wireless card in your laptop. Then it should hook to your wireless router. Note...If you have the security set on the wireless, it will have to be also set in the laptop to be able to hook to your router Please take time to rate me thumbs up
Read more: Toshiba Satellite Pro L20 ' Laptops ' Reviews ' PC Pro http://www.pcpro.co.uk/reviews/laptops/81410/toshiba-satellite-pro-l20#ixzz1XxqUaS8K
Sep 14, 2011 | Computers & Internet
I bought a toshiba 6100 it has wireless card but i cant seem to figure out how to change it to conect to my wireless broadband conection
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 23, 2011 | Toshiba Satellite Pro 6100 Notebook
Wont conect to internet
do you have an internal wireless adapter? Is the switch switched to on? Are you close enough to the wireless router. Do you have the right security code selected for connection to router? I would try resetting router and modem if the above is not the problem.
Jun 23, 2010 | Toshiba Satellite Pro 4600 Notebook
How to turn on wireless switch on a Toshiba 5205-S505?
First - Determine if your Toshiba Satellite has built-in Wi-Fi. Open the Start menu in the lower left corner of the desktop. Choose "Control Panel" and select "Performance and Maintenance." Click on the "System" icon and click on the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Click on the plus sign next to "Network adapters." Look for a device that has "Wireless" or "WLAN" in the name. If you see this device listed, then you have built-in wireless.
Next - Turn on the wireless by holding down the "Fn" key on the keyboard and then pressing "F8" at the top of the keyboard. Press this combination until the window indicates that Wi-Fi is on. Some Toshiba notebooks have a switch on the front left side of the laptop that will turn the Wi-Fi on. Many Toshiba Satellites have an LED indicator light on the right front edge of the notebook that will turn on when the Wi-Fi is on.
Finally - Click on the Start menu in the lower left corner of the desktop. Select "My Network Places" and click on "View network connections" in the menu on the left side of the window. Double click on the "Wireless Network Connection" icon. This will open a window that lists available wireless networks. Click on the name of the network you wish to connect to and click on the "Connect" button at the bottom. Type in the password if required and connect to to the network. Open a web browser to test the connection.
Apr 15, 2010 | Toshiba Satelite 5205-S505 Notebook
Can`t conect to wireless router does a100 have wireless capability
It does have wireless, look for the manual switch, its next to the two usb ports by the DVD rom drive. Good luck!
Dec 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
Bad wireless network conection?????
It could be because of a few issues. The signal from the wireless router could be too weak, try moving closer to the source of your wireless access. The wireless adapter could be faulty. There could be something in the area that is interfering with the signal (another device running on a similar frequency).
Mar 24, 2009 | Toshiba Satellite M35X-S109 Notebook
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
How do I go Wireless with my Toshiba 5205-S505 Laptop?
for getting wireless u need the following: a wireless access point or a router..access points are easy to configure..good ones are from linksys(other brands are Netgear,D link,Belkin etc) Linksys WAP54G Wireless-G Access Point..and your pc/laptop needs to be wifi enabled..if they are not you can get a USB adapter again from Linksys..just follow the instructions and you are good to go!do secure your wifi network once you make it..hope it helps!
shall be glad to help further..
Nov 19, 2008 | Toshiba Satelite 5205-S505 Notebook
HP Pavilion dv6000z Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
