Question about Apple iPod nano
Ipod my ipod is stuck...i can hold him or unhold him..but when i move my finger around it doesn t respond to that...
Ok put it on hold un hold it and then press menu and the middle button till you see the apple sign hope i helped!
Posted on Feb 02, 2010
On/off button tell me i did not see
To turn on the ipod nano press any button.
To switch off the ipod press and hold play/pause button.
Make sure the hold key in put in unhold side.
Thank You
Aug 30, 2010 | Apple iPod nano
It's stuck and won't play the songs
  1. First make sure that your iPod’s hold button is of. (This is the little switch at the top left corner).
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
Aug 27, 2010 | Apple iPod nano
IPOD Nano is frozen
This is a video showing you what the above poster wrote out! Hope both solutions are helpful!
Aug 22, 2010 | Apple iPod nano
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
Aug 03, 2010 | Apple iPod nano
Frozen
Start by resetting the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If this does not work to resolve your issue, please do let me know :)
Jul 02, 2009 | Apple iPod nano MP3 Player
The clicker located at the bottom, center of my ipod touch stopped responding and ive already re-started multiple times. what do i do? the serial number is: 1B741YS1W4T
it is possible the the button is just stuck or crooked in the cradle it sits in.
when you look at the ipod is the square on the button turned at all if so push it with your finger and turn to straighten it. it has 2 channels it is supposed to line up with.
also maybe it is dirty and stuck down. try clean around the edge with a qtip with alcohol but not so much that it is wet.
If this doesn't help you may have to have a tech open it and see why the button is not responding.
May 17, 2009 | Apple iPod touch
My nano 4g will only respond to a shake, nothing else
have you tried to reset the ipod yet? I've included a step by step below just in case you are unfamiliar with reseting your ipod. Many user are LoL ;)
Apr 26, 2009 | Apple iPod nano
Ipod classic 160gb
I had the same problem. Try this: Toggle first Hold Button, push to Hold then leave it Unhold. Then long press Menu Button and the Center Button together for 10 seconds. Voila! There solves your problem.
Oct 18, 2008 | Apple iPod classic MP3 Player
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Operate an ipod
To get it unlocked: Find a black (or silver) oval switch on it. Move the switch to the left and orange will appear. Your ipod will be unlocked.
To scroll through things: Move your finger around the black circle.
To select something: Press the center black button.
To shut your ipod off: Hold down the pause button (button on bottom of scroll circle) for three seconds. Then switch the hold button to the right to lock it.
To pause something: Press the pause button (button on the bottom of the scroll circle).
I hope my solution was helpful. Please rate it.
Jan 17, 2008 | Apple iPod nano
Apple iPod nano Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
