Question about Refrigerators
The seperator between my Hot Point side-by-side, the piece of metal that is inside the refrigerator that seperates the fridg. and freezer is very hot, where the doors close on...why???
  • 1,531 Answers
This is usually an indication that the condensor an has stopped working and is unable to cool the condensor lines and this heat is being transfered to the rest of the fridge .
Posted on Feb 02, 2010
Our side by side fridge freezer drain hole is plugged.we cannot find where it is inside the freezer.just on the back of freezer at the bottom. Where is it inside the freezer so we can pour hot water in it...
Good day,
You may have to remove the back panel in the freezer to get to it. It's there. It is always at the lowest point on the drain pan located below the cooling coil.
It may be, if there is ice laying in the pan, you can't see it. In that case, slowly pour hot water on the pan, and let it start to melt the ice.
Don't use any metal devices to force the situation. Make sure the machine is off.
Patience is your friend here.
Nov 01, 2010 | Maytag MZD2766GES Side by Side...
Can this GE TFX side by side be used as an extra frig in a garage that gets very hot in summer
most (not all) f/f can be used in ambient temps from about +5C to +35C,but use a seperate thermometer to keep the interior temps at +5C for a fridge and -18C for a freezer.
Oct 31, 2010 | GE GSH22JFR Side by Side Refrigerator
My refrigerator is not getting cold,but the freezer is working and the trim that seperate is very hot
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Stripe between fridge and freezer is extremely hot to touch
It is 100% the condensor fan motor on the back. Its not two hard to replace. Take the screws off the back panel and remove. Then locate fan. Disconnect the wires going to the motor and then unscrew the scews that mount the motor. Take the part to parts store of look it up online. Then simply remount motor and plug wires in.
Golden.
Jul 29, 2009 | Whirlpool ED2FHEXN Side by Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
