Question about Microwave Ovens
We are pushing start and the light comes on and the microwave acts like it wants to start, but it just doesn't. Since the light comes on, we know it is not a fuse or power issue, right? Any help would be greatly appreciated. The model number is JMC8127DD/JMC8130DD and it is an over the range microwave. Thank you very much for your time, Kari Johnson 720-304-8060 robrjohnson@msn.com
  • robrjohnson Feb 02, 2010
    Would this be a fuse, though, if the light is indeed coming on. There is some power then, right? When you push start, the light comes on and the next step would be for the roundtable to start moving, but it doesn't.
    Thanks,
    Kari
    Great! Thanks so much for the turntable advice. I am assuming I just unscrew the plastic piece in the middle of the bottom of the microwave where the plate fits in, right? And this will be where I will find the turn unit, correct?
MicrowaveSvc
  • 9047 Answers
SOURCE: maytag microwave model#mmv500adb
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Feb 19, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sanyo EM S8000-w microwave range quit..fuse?
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
Posted on Jul 01, 2008
Start enter button not working
If you know how to repair microwaves, see these youtube tutorials:
Fixed microwave number pad
Quick repair GE microwave touch control key panel doesn
Samsung Microwave SE 5E Error Fix
Lg Microwave keypad repair
No light? You can look for more videos or take it to a repair shop
Jul 13, 2015 | Microwave Ovens
When I push a button to start the mircowave, the timer counts down but the microwave doesn't come on.
It sounds like part of the electronics driving the magnetron (yes its a real word) have failed. So you could take it back, or get it repaired, or replace it. The repair costs would be similar to buying a new one, so I would buy a new or used one, but buy a japanese brand like panasonic instead. My Panasonic micro is 17 years old and still working.
Dec 19, 2013 | Jenn-Air JMC8130DD Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Frigidaire FM156DSB 950w #7G63610032 light and timer works but microwave will not come on. When you push start it just clicks and does nothing. You can push up on the door from the bottom and microwave...
I have the same problem with ours! The light will come like it should but the microwave will not start until we hit the upper part of the door handle. Any advice?
Jan 21, 2011 | Microwave Ovens
My daughter put a metal ring in the microwave to heat up. I was not there, so I did not know what happen and if sparks flared up. But the microwave kept working OK for half a day before acting crazy. ...
There really shouldn't be a correlation between the metal ring in the oven cavity and the erratic operation of the control board. Although it might seem suspicious, what happens inside the oven cavity stays in the oven cavity.
Jun 20, 2010 | General Electric Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
