Question about Thermador PG486GEBS Stainless Steel Kitchen Range
Oven ("Professional" range) shuts off after less than a minute of being turned on. Blue "Oven" light blinks 4 times, then the blue "Heating" light blinks 3 times. Sequence repeats until turne off.
  • 11,896 Answers
Is this a gas range or electric? If electric, it could be bad heating elements. If gas, it could be dirty/corroded internal heating probe inside the pilot itself and needs to be cleaned with a wire brush or the gas valve has a weak spring and is not staying up to allow gas flow.
Posted on Feb 02, 2010
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Jun 03, 2014 | Frigidaire Ovens
Turn oven on. shuts down in less then a minute
Possible there is a trip due to a fault in the oven wiring or the heating coil. It is ideal to isolate the connection to the unit/burner/igniter and cross check to see the functioning of the circuit so as to confirm the wiring.
May 09, 2011 | Thermador P304CS Gas Kitchen Range
Our 6 year old Kenmore Electric Range's oven just quit working. The stove top burners work fine, the light in the oven comes on and the breakers in the main house panel are all fine. It just quit heating...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Kenmore Kitchen Ranges
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Apr 15, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
Nov 10, 2007 | Whirlpool SF367 Gas Kitchen Range
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Thermador PG486GEBS Stainless Steel Kitchen Range Logo
123 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
