Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My sony projection tv will not work
When the power is turned on , the tv will light up for a fuw seconds and then go off. what causes that ? I changed the lamp but it did'nt correct the problem. any advice on what I should do next ?
  • Sony Master
  • 5,138 Answers
Ballast Board Call Encompass Parts 1-800-638-3328
CK your Lamp Fan
Posted on Feb 02, 2010
Typically the power button blinks green for a few seconds before turning a solid green as the lamp lights up. Now the power button just blinks green indefinitely, without the TV ever turning on. I figured...
Hello Jeremy,
May be some IC or capacitor is damaged due to which TV is not turning on. Please contact the service center of the Sony. They will repair it properly.
Dec 26, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I replaced the lamp and it still doesn't work
You can try to reset the lamp timer. Check your manual to see how. If that doesn't help, your power supply may be bad. Then you should seek a repair service.
Feb 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony grand wega model kf-42we610 I will be watching tv and it will turn off on it's own and then come back on 30-60 seconds later. If I turn it off the light under the power button will blink 5...
Check your lamp cover on the rear it may be loose which will cause the tv to turn off. Also the light under the power light is the lamp indicator. If it is blinking it may be getting ready to fail.
Jan 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
