Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD52525 Brightness
Replaced lightbulb but the picture looks dark without clarity and dull, opac.
Any suggestions??
  • Anonymous Apr 16, 2009
    contrast all the way up and picture still not that good. picture looks dull.
    President:
  • 4,402 Answers
Mitsubishi Caps cause dim Picture faulty capacitor issue in the WD-52525 does seem to be prevalent at the 3 yr mark. At the bottom of this long-winded comment is a link to another discussion forum similar to this one where we obtained the service manual, chassis replacement manual, and encouragement to attempt the repair ourselves. My husband and I are not experts by any means, but my husband did have the tools from previous electronics projects to solder. So we took a chance on looking for bad caps. And I am here to say that I’m so glad we did because there were 2 obviously swollen caps that were easy to replace. The picture is now even better than when the problem first occurred since we dusted the mirrors and screens while we were in there. NO WINDEX. Just a dry micro-fiber cloth did the trick. We'll probably do that annually going forward.
According to descriptions from several people, the symptoms and degrading image due to capacitor failure can take various forms. In our case, we had a lamp blow out 2 wks before the TV died. And I do mean blow out, not burn out. We didn't get any lamp replacement warning. It flat out blew the 1-yr old bulb to shards of glass inside the casing. We replaced the bulb with a brand new one like good stewards of a DLP HDTV should do. A mere couple of weeks later we watched the image degrade over the course of an hour through various stages until the new lamp simply wouldn't light anymore and there was a solid black screen and solid red lamp light even though the lamp itself was fine. The trouble-shooting diagnostics (pressing MENU and DEVICE buttons on the front panel) gave the 3-4 code indicating a lamp abnormality. But ultimately the problem was solved by replacing the C9A37 & C9A38 caps (both are 10V 3300M-M 105C). We did not have to do any repairs on lamp or ballast components. The cost of 2 new capacitors from Digi-Key including shipping was about $14.50.
Some folks have stated that they were able to do the repair without removing the power supply chassis from the back of the TV. That was not the case for us. It was a bit intimidating at first. But we disassembled everything, labeling as we went, so we could freely inspect and access all boards on the power supply. There are some tiny, very hard-to-reach connections between the power supply and the ballast. For this reason, I also recommend disassembling those ballast components from the frame. They're simply too fragile to force in a very tight space when reconnecting.
Lastly, I am still pleased with this TV. The color and clarity can not be rivaled in my opinion. Even after having gone through this, compared to the problems reported in some of the other threads on issues with whatever other brand name or model you pick, this is a relatively easy repair that can be DIY. This was why we went DLP in the first place. And it is why we will probably remain DLP fans until they aren't made anymore. But next time, we’ll go with an extended warranty for sure!
I do wish Mitsubishi would at least acknowledge the issue. I don't even expect any reimbursement, replacement, refund or anything like that. I'd just like to know that THEY know there's a simple problem to resolve and that they're doing something about it.
http://www.avsforum.com/avs-vb/show...=418307&page=84
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
Picture is dark. cleaned the lens and tried to adjust brightness
have you changed the bulb. over time it will go dark as the bulb burns out...
Oct 21, 2013 | Mitsubishi WD-73C9 73" DLP TV
What is the picture settings for wd-73834 mitsubishi hdtv
Most of this is personal preference---if contrast (picture) is set too high the picture will have some smearing on dark or even very bright scenes--try to have that set at about 70% and brightness just a bit higher---a proper setting of the two will give a better picture with more clarity. Color and tint to preference and sharp to not full smooth (mid-range)
Other than these signal provided accounts for clarity--pixels stopping etc is not the set but the signal provided not fast enough to keep up----cable and sat often jams a lot of info into a small space and that sort of issue results.
If you have a HD quality Blue Ray compare it to your signal source and usually it will look much better.
I have taken the time to cover as many bases here as possible.
Hope it helps in some small way.
SD TECH
Aug 27, 2012 | Mitsubishi WD-73734 73" Television
Have a Mitsubishi Model WD-62528. Picture is dull and colors anr not viberant. What can I do to get the great picture I had. Changed light about 4 months ago
I notice the same thing with my 62" after several years -- the problem was dust on the inside if the screen. Take it off (have someone help you - it's big and bulky) and carefully clean the dust and also in my case cobwebs from inside the encluse - this made a huge difference for me in picture brightness and clarity.
Nov 25, 2011 | Mitsubishi Televison & Video
I replaced the lamp in my Sony KDS 55A3000 and the picture looks dull. I have tried to adjust the all the settings but that has not helped. I have to set the picture and brightness settings all the way up...
bkfin,
I would check to make sure the lamp is inserted correctly. Usually there are rails for the assembly to slide on and it must be in the rails and inserted completely. Take it out and make sure there is nothing covering the path of light and the lens is clear and clean. Reinsert properly and carefully and try the unit again. You should also compare the old lamp and new lamp while you have it out and make sure they are identical and have the same light output in watts. This should solve your problems. If it does not I would return the lamp and ask for a new unit.
Thanks for using FixYa and the generous rating.
hardrocko
Sep 21, 2010 | Sony KDS-55A3000 55" HDTV
Sony KDS 50a2020. Tv Seems to Dull. not a setting.
Two possibilities:
1. The lamp. When did you last replace it? They will dim over time and lose focus, clarity, brightness and sharpness. If it has been 18-24 months, and this is your main tv, consider replacing it.
It's a F-9308-860-0. They go for about $175.00.
2. Let's say you follow my advice, put in a new lamp and the picture is still dim, dark, dingy and fuzzy? Then you, my friend, need a new Optic Assembly. The thing your lamp shines into and the thing that gives you a picture to look at. They can fail or wear out for all sorts of reasons--too many for me to type out now. But, suffice to say, if you have recently replaced the lamp (less than 6 months) and are experiencing a drop in brightness, consider getting on the phone with Sony. Even if you are out of warranty, your set is covered against Optic failure until June 30, 2010.
Hope this helps.
Jan 21, 2010 | Sony KDS-50A2020 Television
The tv has a haze look to it. Looks really washed out.
Thats usually caused by the front small mirror which gets dusty and the image will get very dull and washed out. Cleaning the small front mirror will restore the clarity and bright colors again. use just a damp cloth with water then dry thoroughly. If you dont know how to gain access to the small mirror up front you can get the service manual for that model emailed from the following link, It has the disassembly instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
Dec 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The picture is fading.. I replaced the lamp. did not work
if the pic is just dull and no longer crisp. polishing the small mirror up front will restore the clarity and brightness most of the time.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Jan 26, 2009 | Protron PLTV-4250 42 in. LCD Television
Usually a bad lamp. If the lamp you replaced is new, then cleaning the internal mirrors (especially the small triangular one) and clean the projector assembly as well. The lamp ballast supply may be weak as well, but I seldom see this.
Mar 04, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
452 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
