Question about Goldstar Microwave Ovens
I ran the microwave for 15 minutes with nothing inside. It no longer heats.
  • 254 Answers
Possibly a fuse inside or a diode...... those are fairly cheap repairs if those check out okay it might be a magnetron or high coltage transormer,,take it to a service shop dont try and test those yourself high risk of shock without groounding the capacitor first.... i hate to tell you these days that micros are disposable items if u were to get it serviced after its all said and done you will have put enough money into it to buy a new one hope this helps
Posted on Feb 02, 2010
Testimonial: "Thanks for the help!"
TECH MAG 6 TRAINER gets hot and makes noise after I use it for about 15 minutes
Sounds as if it is not ventilating the heat properly, which is causing a safety mechanism to be triggered to shut down the microwave in order to save the motor.
The vent could be blocked, the fan/fanswitch went out, or the heat sync is no longer properly transferring heat. Depending on the age the solution would to call a repair man or replace the microwave. And never use microwave without anything inside of it.
Dec 01, 2016 | Microwave Ovens
Why can't you run a microwave without anything in it? What happens and can you fix the problem? I forgot to put the food in and ran it for 4 minutes with nothing inside. Now it won't heat any food.
A microwave oven works on the principal of a high power high frequency radio transmitter. The device that emits the microwave energy is a tube called a magnetron . When you run the microwave empty with nothing to absorb the microwave energy it is all reflected back to the magnetron causing it to overheat and destroy itself or cause failure in the High Voltage power supply due to excessive current draw.This is caused by standing waves.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Doesnt heat up
in a microwave, there is no heating element. There are microwaves that heat up the water molecules, they make them spin fast and that's what heats things up. Running it with nothing in it, you really can tell if it's not working by that test either, again, nothing to heat up. I would put in a cup of water, set on high for 3 minutes and it should boil, if not, get a new one for the price, why mess around?
Mar 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
We accidentally ran our sharp R-510B microwave for 15 minutes on high with nothing in it. the result was an unpleasant chemical smell and a non-functioning micro. when we run it now, the light & fan...
That doesn't sound good at all. Microwaves are death traps. It could have melted some metal inside. A fuse could have gone, but most likely the magnetron is shot. Might be safer to recycle and reinvest in a new microwave, especially for safety sake when dealing with controlling radiation.
Apr 24, 2008 | Microwave Ovens
Microwave Ovens Logo
264 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
