Question about Yamaha HTR-5890 Receiver
I have a yamaha htr 5890. I would like to hook up
I have a yamaha htr 5890. I would like to hook up a set of remote speakers using the zone 2 output. I have tried by turning on the amp in the zone 2/3 options menu, but i get no power to the remote speakers. I used these remote speakers with an Onkyo ts xr601. They worked great. Thanks
Rob
  • 3 Answers
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Posted on Aug 10, 2010
Can I hook up wireless speakers to Yamaha HTR-5830?
there are wireless kits available, and most all yamahas have pre-amp outputs for all the channels
Feb 28, 2013 | Yamaha HTR-5830 Receiver
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I have 4 speakers connected 2 on A channel and 2 on B channel....Was listening to a dvd music concert at + 1.5 volume on my Yamaha HTR 5890 receiver,after 5 min my amp shut off and I was never...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-HTR-5890-Receivers-review-manual/id/394ci071/t/1-2/
Page 25 discusses the minimum speaker impedance setting for expected lower-than-8-ohm loads. Running A AND B may present a load that is dangerously low. BTW: 6 is not a whole lot lower than 8.
Look at your speakers' impedance specs. Running them in parallel would present a much lower load than either pair alone.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You very well may have blown and amp or a speaker.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked
Mar 04, 2011 | Yamaha HTR-5890 Receiver
Zone front and Zone B?
A and B is for two sets of front speakers. Which one you choose for surround sound depends on which terminals for front speakers included in a surround sound setup that you actually plugged your speakers into.
Terminal B is designated for the output of sound to a second "zone" ie; another room for example, if you have another set of front speakers connected to it.
Apr 16, 2010 | Yamaha HTR-6030 Receiver
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Oct 17, 2009 | Yamaha Audio Players & Recorders
Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Sep 08, 2009 | Yamaha HTR-5890 Receiver
I am looking to add 2 speakers onto a HTR-5590 by utilizing the Zone B. I would like to set the volume just for the Zone B speakers so that they are at max volume. This way I can control them with the...
If you want separate volume control on a different zone you would have to have a separate gain control available, such as with your center and surround channels for example.
If that option is not available and you have only the master volume control for both zones then you could use active speakers connected to the zone 2 preouts, but being able to control the volume with your extra remote with that setup requires more equipment.
Jun 17, 2009 | Yamaha RX-V661 Receiver
Yamaha HTR-5890 Receiver Logo
422 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
