Question about Sony VAIO VGN-FW290JTB Notebook PC
Vaio notebook doesn't turn on after unexpected shutdown
Hello!
I was using my vaio notebook, and when i pluged in an USB extension cable (i don't actualy know the correct designation for this), the notebook just shuted down, and now it wont turn on.
what should I try, before I have to pay for the repair? it is not in warranty anymore..
thank you in advance for any help! :)
    Scholar:
  • 154 Answers
Hehe, i understand.. the repair is expensive
try this first
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can, if not, its ok
  3. without the ac adapter and battery, press and hold down the power button for 7-10 secs
  4. reconnect the ac adapter and the battery
  5. try turning it on again
hope this helps//
Posted on Apr 10, 2010
Vaio fs920 will not connect to wireless internet
I'm assuming you are still using WinXP on this machine? If so make sure you have Service Pack 3 installed since XP doesn't have native support for newer wireless encryption standards like WPA2.
If you are using WPA2 encryption on your network then try setting it to an older version like WEP and connecting that way, if that works but not with WPA2 then you don't have the extensions for the newer encryption protocols installed that come with Service Pack 3.
Jul 03, 2012 | Sony VAIO VGN-FS920 Notebook
Hallo, I have a Lenovo ThinkPad SL510 2847 and I get unexpected shutdown in a different intervals. It may be for example 10 minutes or 3 hours after the Windows starts. The system is ready to start...
It could be that the machine is overheating, if it's shutting down. Try ensuring that the vents are clear of obstruction, and that they are clean. If you can get to the cooling fan, then ensure that this is also clear. Don't use the laptop on your lap, as this tends to block the cooling vents as well.
It may also be worth checking to see if you get any error messages before it shuts down - in case it's something different (although I know that Windows 7 doesn't have an SP2 yet - so are you using Vista, or 7, SP1?)
Jul 23, 2011 | IBM Lenovo ThinkPad SL510 Notebook
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Jun 19, 2011 | Western Digital Elements powered by WD 320...
My SerifDrawPlus X3 reboots unexpectedly after I apply image effects to an image...reads "program closing windows 7 is trying to find solution to this problem" - can you help?
This could mean your PC overheated, had a error or another problem causing Windows to force it to shut down. Is the fan in your PC working right? If it isn't working (correctly), buy a new one. If you don't know how, here's a good guide how to. If it is working correctly, a error might caused it. If so, Windows 7 will find a solution for it. Check the white flag next to the internet and volume icons. If these to are not the case, your PC might doesn't have enough memory to hold image effects and too less RAM (Memory) could cause a unexpected shutdown. Don't hesitate to ask me more! Thanks for using FixYa, and have a great day.
Jun 04, 2011 | Computers & Internet
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
Jan 24, 2010 | Porter Cable 75182 Variable Speed Router...
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
4 Port USB 2.0 Smart Hub Pro with Power Supply Part No. 42999
Slap a voltmeter on the Power Supply for the USB Hub and make sure it is still working. It really sounds like what happens when you connect a device to a unpowered hub that is not capable supplying enough power.
Feb 28, 2017 | Ultra Products 4-Port USB Hub
Aspire 5630 - Unexpected shutdown!! This weekend, the laptop just shutdown without any warning! I switched it back on, and then after 30 mins, the same issue!!! I checked the battery, and was charging OK....
Depending on the age of the laptop, it could well be overheating. Let it cool down good, and try again. If that is the problem, you will have to clean out the cooling system with a can of air.
DO NOT USE AN AIR COMPRESSOR ! ! !
Mar 16, 2009 | Acer Aspire 5630 Notebook
Wifi controller for PS3, Does radio signal turn off when USB is plugeed in?
The Bluetooth radio signal will stay active as long as the controller is turned on, the USB cable doesn't switch the radio signal off.
Jul 28, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony VAIO VGN-FW290JTB Notebook PC Logo
240 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
