How to adjust vertical size on Panasonic CT-27G14A TV
I have a Panasonic CT-27G14A TV which works perfectly except that the picture is slightly vertically stretched. I learned how to access the service menu, only to find out that the service menu on this model does not provide a vertical size adjustment. .
So, I'm assuming there is a trimmer pot or coil inside that I need to tweak. Can someone give me a clue on how to find it and proceed with the adjustment? Thanks in advance!
  • Dennis X Feb 02, 2010
    Thanks for the reply! I don't understand everything you wrote, but I think you're saying that under "B" in the service menu there are submenu options to adjust vertical size. I'll give it a try, and thanks again!
  • Girish Bhat
    Girish Bhat May 11, 2010
    in set up icon..set antenna to cable. in timer icon,set sleep timer to 30 exit menus and tune to channel 124 adjest volume to o press volme down on controal panel& red chk will appear to adjust vertical mode press power button on remote 'B' vertical sub adjustments "C"W.B ADJUST "D" pincushion adjust ments "s" optional adjustments..go to b &adjust v-height
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
Panasonic CT-27G14A
Have you tryed both the front and the back inputs?
May 17, 2008 | Panasonic CT-27SL15 27" TV
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
Mar 15, 2012 | Panasonic CT-27G14 27" TV
I bought a panasonic model ct-27g14a tv from a thrift store when i got it home i found that the parental lock was activated and did'nt have the code.
Sorry,u must have it orignal codes,there noway to unlock secrect personal codes.U push the channels + or - buttons manual controls couples times.Might get in the tv input.Hook up,use it with DVD player can watch DVD Disc thought.Sorry, you probally only can watch shows rated Y for children only.
Jun 02, 2010 | Panasonic CT-27G14 27" TV
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Televison & Video
Televison & Video Logo
464 people viewed this question
Top Televison & Video Experts
Electro Med Services...
