Question about Calibre Radar Detector
HOW DO YOU RESET THE UNTIL
HOW DO YOU RESET K 40 UNIT ITSELF
Reset V-Chip
Reset the TV by pressing "Action" and "Power" together on the TV itself (not the remote) for at least 5 seconds or until the unit turns off.
Aug 13, 2007 | Panasonic TC23LX60 23In Flat Panel Lcd Tv...
I set the humidity level and it immediately goes back to 90. Do I have to wait until the humidity level that I have set is reached and then it will show that number?
At 90, there's little chance the dehumidifier will remove any humidity. That setting is simply to high.
It may be that the unit needs to reset itself. You can accomplish this by turning the Master ON/OFF Switch to OFF and unplugging the unit for 15 minutes. Then, plug the unit back in and turn the Master ON/OFF switch to ON. Set the humidity extraction level on it's lowest setting. Hopefully, the unit reset itself and will now function as it should.
If that didn't solve the problem, the memory board may need to be replaced.
Hope this helped you to troubleshoot and solve the problem.
May 31, 2011 | GE Dehumidifiers
Getting eaaf error code
Internal Temp is below 40 degrees. To remedy this, take a hair dryer, and heat up the heat sensor until it is above 40 dgrees. The unit should start to heat up. Keep it on the sensor until the unit is heating for a minute or two, it should stay on after that.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
My blue ray won't play blue ray disc's it's already played and it won't play new ones
You can try getting it professionally cleaned but it sounds like you need a mechanism unit and that exceeds the cost of a new bluray player substantially. Make sure you have gone into the menu and under software update there is system reset. Make sure you have completed that system reset and make sure you have the latest software update installed. Sometimes after playing a movie you have to complete that system reset in the menu and the reset whereby you hold down the power button ON THE UNIT ITSELF NOT ON THE REMOTE CONTROL until the unit says reset.
Sep 27, 2010 | Sharp AQUOS Blu-ray Disc Player
How do I reset the Panasonic PT-40LC12 projection TV's lamp hour meter. What is the command?
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Jan 20, 2010 | Panasonic PT-40LC12 40" Rear Projection...
My samsung mp3 player is frozen on. It won't let me do anything, including turn it off. If I press the reset button will that erase everything on it? Anyone know how to fix this??
Reset the unit by holding down the REST button until the unit shuts off by itself.
Resetting the unit will not delete files off of the player
Jul 08, 2009 | Samsung YP-S5 MP3 Player
I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Clock Reset
Hold the memory button in which is located on the top of the unit until the clock digits flash. Set the hours by holding the up or down arrows on the skip buttons which are again located on the top of the unit until you get the correct hour. Then press the momory button once more for the minutes and set these again using the skip up and down buttons. When time correct press the memory button again to set.
Simples....
Mar 13, 2009 | Audio Players & Recorders
Calibre Radar Detector Logo
169 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
