Question about Jenn-Air Refrigerators
DOES JCM22BDS HAVE A 10 YR WARRANTY ON THE SEALED UNIT
  • 254 Answers
Where did you find that model number i cant find anythin on it..... open your refer and look on the inside wall for a sticker or tag it will list your model number,, post that and i will find out ,, k sooory i will help if you can find that number
Posted on Feb 02, 2010
When compressor kicks in it throws the breaker
Could be a bad breaker, which would be the inexpensive fix or you could have a short in your compressor, very expensive to replace. If it's still under warranty (most have 10 yr), you may just have to pay for labor. If it's and older unit, it may be better to replace the entire unit with a newer more efficient unit.
Jun 06, 2014 | Gibson Nordyne/4 Ton Heat Pump Package...
ENDURA POWER BUTTON BROKEN
Sounds like the power button is pulled loose from the circuit board or the power switch went bad for some reason. You can't check this out as it is sealed to be waterproof and opening it violates the warranty. The only way to address this would be to send in to Lowrance Customer Service.
This should not be a common problem and should be covered by manufacturers warranty if still within the 1 yr warranty period. If out of warranty, Lowrance Customer Service should still be able to replace or repair it for some sort of cost.
To speak with US based Lowrance Customer Service, call toll-free at 1-800-324-1356, Monday through Friday from 8:30 am to 4:45 pm Central. Or email them at products@lowrance.com with problem, product model and serial number (located between the batteries in the battery compartment). CS On Hold times range between 0 and 4 minutes right now with Monday mornings being their busiest times.
A Lowrance Guy
Jan 30, 2012 | Lowrance Endura Out&Back Handheld GPS...
Got a black&decker cordless drill on 10/16/09 and the ac/dc recharger no longer works. is that still under warranty? Got it from home depot with a 90 day return policy, but think its...
I would need to know what model your drill is to be sure but many B&D drills have 2 yr warranties. Some of the lower end drills are 1 yr and some of the professional grade products are lifetime.
Sep 19, 2010 | Hand Tools
Frigidaire dishwasher model pdl4375rfc2 serial# th80537081 door weaks aat lower right corner user less than 6 months is there a recall on this model
if unit is less than a year old . call for service 1-888-203-1389. this unit has a one yr. warranty from the manufacture. recalls are usually not given on appliances unless it is a safety issue. however i have repaired alot of these under warranty for your same complaint. their is a splash kit u can get that goes on each corner of the bottom of the inside of dishwasher that will stop it from leaking, roughly 10-20.00 dollars depending on who u purchase it from .hope this helps out.
Oct 06, 2009 | Frigidaire PLD4375RFC Dishwasher
Whirlpool window unit a/c power comes on but no air comes out
sounds like a bad fan motor or capacitor. mostlikely covered by your warranty
Aug 21, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Where do yo put the trans. fulid in a 5 speed
should be a service plug on side of transmission
Aug 16, 2009 | 2000 Kia Sportage
Replacement Repairs
most units have a 5 yr parts warranty but you would be resposable for labor.
Aug 09, 2008 | Weather King Heating & Cooling
Washer GLTF2070DS0
warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Noise vibrations in dehumidifer
sounds like a sealed system issue it has a 5 yr. warrenty on the sealed system, cost to repair might mean an new one instead
May 03, 2008 | Dehumidifiers
Refrigerators Logo
37 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
