Question about Acer 91.63X07.001 Keyboard
HOW TO REMOVE ACER 6292 LAPTOP KEYBOARD - Acer 91.63X07.001 Keyboard
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 49 Answers
You can reference the article :
How to Remove and replace laptop keyboard
Posted on Feb 10, 2010
3 Suggested Answers
ser71
  • 818 Answers
SOURCE: keyboard laptop removal for acer 2420
I took it apart b4, and took them apart roughly (the notebook is now not with me) as follows:
1. Wiggle or pop out or take out the cover plate, i.e. the cover with power switch and lights
2. You will see 2 or 3 screws, unscrew them and then wiggle the keyboard out (pull the KB towards the screen direction).
3. Be very careful with the ribbon behind the keyboard .
The most diffiuclt part was to re-assemble the ribbon back to the motherboard. Its very easy and took about 10 minutes to replace the KB. Thats about it.
Sergio
Posted on Mar 13, 2008
techresolve
  • 109 Answers
SOURCE: Remove Keyboard Acer 6292 TravelMate
Tilak, try to remove the cover above the key board and just below the lcd screen, though it will look like it cannot be removed but it can be, below that you will find few screw which hold keyboard with the rest of system n you are at ur place, now do it urself.
Posted on Apr 15, 2010
Replace key to keyboard
Learn how to remove and replace keyboard key of Acer laptop - http://imgur.com/a/asQTR Simple Steps to Replace Acer Laptop Key
Mar 19, 2013 | Acer Computers & Internet
How to fit memory in acer travelmate 6292
On this laptop you can use 2 G of ddr2 on 667 mhz ..If the size is not a must be ..and can be 1 G or 512 modules the speed need to be the one specified so to work without problems ..and also the type (ddr2 sodimm )
If you think this is eh case...Just open the lid for teh ram memory on the back ..and if teh slots are already having 2 modules..just remove one ..if it is smaller and use the 2 G one in its place ..Usually it came with 2 G of memory ..and if it is in one slot it will have one free but it can be in 2 modules one G each ..in this case it is even better cause you will have 3 G in total and you can avoid some of the troubles some found when using the max memory ..(boot up problems )
here is the procedure exactly in a video ...I suggest to reinstall teh operation system after upgrading for to work on full capacity and avoid issues that might appear ..(the system may not see the memory or have difficulties..But usually will work just with a restart or a bios reset to factory settings ..)
http://www.youtube.com/watch?v=EdjceQNzFSQ
This is for a different model but same kinda ddr2 modules ..and also a travelmate ..so the difference may be just in the cover ..but inside they are the same on the procedure ..remove the on eon top ..and install the 2 G module ..If it only have one module ..remove it ..to get to the bottom one ..and install the module and put the one you removed back in ..
good luck and please rate my answer ..
Dec 21, 2011 | Acer TravelMate 6292 Series Laptop Charger...
Apr 15, 2010 | Acer 91.63X07.001 Keyboard
My acer travelmate 6292 wont boot into windows. It goes into a blue screen after I hit last known good any version. It freezes up when I try to boot in any version of safe mode.
Hi
Unfortunatley your Laptop is suffering from the blue screen f death, if you cannot get into safe mode then unfortunatley you will have to reformat the laptop
If this has been useful please leave positive feedback/vote
Feb 11, 2010 | Acer TravelMate 2300 Notebook
My acer travel mate 6292 can't boot up because the return key is not functioning. I requires me to enter my password when I turn on but it can't be executed because the return key is not working even I...
To get you buy temporarily, buy a portable flexible laptop for 15 bucks at Bed, Bath and Beyond (they have a nice little gadget area) This will allow you access, the keyboard can be rolled up when not used and is USB. Then either search for a "key" or the whole keyboard on Ebay...they are usually 15-25 bucks. Below is the service manual for your laptop for disassembly of needed components.
http://tim.id.au/laptops/acer/travelmate%206292.pdf
Oct 19, 2009 | Acer TravelMate 2300 Notebook
I like to know how to remove the keyboard for my acer 5050 laptop?
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Jul 14, 2009 | Acer Aspire 5050-3242 Notebook
''NEED TO REMOVE THE KEYBOARD ON A ACER ASPIRE 3680 2233''
Remove the screws on the both hinge,be carefull when you revove the keyboard backwards, its all plastic and verry verry easy to breake.
Nic
Mar 12, 2009 | Acer Aspire 3680 Laptop
Sound problem and battery back pu problem.
http://support.acer-euro.com/drivers/ftp/ftp.html
follow that link
go to the folder NOTEBOOK
that will take you to the ftp-server, when u are there you will find the Travelmate 6292 folder almost at the end.
Good luck
Nov 24, 2008 | Acer Aspire 4720 Notebook
How do I increase the screen brightness of the Acer Travelmate 6292. I have tried control panel - power options but screen brightness adjustment doesn't feature on it.
You need to press the blue FN button and the brightness up or down button.
looking at the laptop keyboard I suspect its either the up and down keys or left and right
let me know if you need anything else or further assistance before rateing.
Thank you,
Ekse
Jun 27, 2008 | Acer Computers & Internet
How do I replace laptop keyboard ?
Praf, You?re in luck, its fairly easy and Acer has detailed instructions with pictures no less. Here is the link: http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=882&formid=3390&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7 Let us know if you have any other questions and please don?t forget to rate this post.
Apr 24, 2007 | Acer 91.63X07.001 Keyboard
Acer 91.63X07.001 Keyboard Logo
561 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
