Question about Sharp CD-BA300 CD Shelf System
"PROTECT" in Display
The word "PROTECT" came up in my display, and the device doesn't work anymore. Any suggestions at all would be very helpful.
  • 56 Answers
Probably your output amp. is worn out
Posted on Feb 19, 2008
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
My CD drive doesn't work
Your display adapter is the component of your computer that allows your monitor to work. On the operating system side of things, this display adapter is controlled by a device driver. If you're having issues with your display adapter (like colors are displaying incorrectly or the screen is flickering), you can fix these problems by rolling back your device driver using the Windows Device Manager.
Open your Control Panel by clicking "Start" and then "Control Panel." Click "System." Click "Device Manager." Scroll down to the "Display Adapter" heading. On a single monitor setup, there will only be one device listed under "Display" adapter. Right-click it and click "Properties." Click the "Driver" tab. Click the "Roll Back Driver" button. This will uninstall your current display adapter driver and reinstall the last version that worked properly. This will fix the issues you were having with the device. Hope this helps
Jan 16, 2013 | Acer Aspire 5735 Notebook
Fuzzy screen hp mini laptop
Try updating your graphics driver through Device Manager.
1. Right Click on "My Computer" on your desktop
2. Select "Properties"
3. Go to the "Hardware" Tab
4. Then select the "Device Manager" Button
5. Click on the tiny + next to display adapters
6. Right click on your display adapter and choose "update driver"
7. Follow the instructions and let it search for a better driver
If this doesn't work then you will need to bring it in to a computer shop to have the screen replaced. Get an estimate first before they do any work on it because it might not be cost effective to have it fixed. In which case you can hook it up to a monitor with a VGA cable to still use it, but it won't be portable anymore.
Good Luck!
May 14, 2012 | HP Mini 1010NR Notebook
May 14, 2012 | Computers & Internet
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Protect comes on why
Hello
Protection display will come over this type of set, when it is overloaded or system confused condition. Just unplug the device from AC mains socket and replug it after 4 to 5 minutes, and see whether it shows any protect display. If it shows it again, just disconnect the output loads, ie, connected speakers, and check. Again it displays 'protect', the internal circuit, especially the output amplifier circuits has the trouble, and the system need service. if it does not show protect display, after disconnecting the speakers from it, check the speakers or its connecting wires for damage. OK.
Jan 20, 2012 | Sharp Audio Players & Recorders
K9N6PGM2-V MSI Mobo no display no beeps after virus attacked,im installing Anti Virus AVAST it stop suddenly the screen becomes dull and grey with white line,so i restarted my PC and it doesn't display...
Your VGA device of motherboard might have problem. and it also can be caused due to some IC failure... you will have to repair your Motherboard as soon as possible. if it dosen't worrks consider replacing your Motherboard.
Sep 01, 2011 | MSI K9N6PGM2-V Motherboard
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Protect apears in display of my carradio Kenwood KDC 3034
I did not resolve my problem and I defenitly am not going to pay anything to you to resolve it. So if you have the resolution to my problem tell me or do not bother to write to my email adres anymore. Thanks for your answer.
Jun 22, 2009 | Kenwood Car Audio & Video
I have seen it like this before!!!
Do you have dual os please specify, if yes, there may be a problem with the bootsector of hdd. to solve this further ask me thx
Aug 16, 2007 | Acer Aspire 3000 Notebook
Sharp CD-BA300 CD Shelf System Logo
193 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
