Question about Zonet (ZSR0104UP) Router
I reset my router and know I can't get it to work at all. Setup keeps asking for a pin says its on the router but it isn't
  • 2,260 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 02, 2010
I forgot my wep key and router username/password
Use first the default username and password according to your router's manual. If it doesn't work reset the router. Look for the reset pin hole on the back of the router. Press and hold it down for 1 seconds.
After that use the default username and password for sure this time it will work. As soon as you are able to access the configuration page of your router please setup a new WEP key to keep you network secured.
May 21, 2011 | Linksys WRT160N Wireless Router
I can't connect to the internet in my house. I have WiFi, but my laptop keeps asking for my 8 digit PIN and I cannot find it. I've tried every number on the bottom of the router...not one of them...
It would have been a password set in the router menu which would be accessible by a IP address in your web browser. You would need to reset the router. This is done by holding in the reset button for 10 seconds. It will reset the browser back to factory defaults. Just keep in mind that if there was any configurations done to get the WI-FI to work with your laptop then they will have to be setup again.
May 14, 2011 | Computers & Internet
Want to reset to factory settings on my Wireless G 2.4 GHz broadband router
you can do that by accessing the router's setup page on 192.168.1.1 or you may want to use a pin and use it to press the reset button for more than 1 min. If that does not work at the 1min mark, keep holding the reset button while unplugging the power and putting it back in.
Apr 11, 2011 | Linksys Computers & Internet
I need a pin no for my router
Start a new configuration.The router can be set to factory default by performing either of these two steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Nov 23, 2010 | Linksys WRT54G2 Wireless Router
I need a pin no for my WIRELESS ROUTER MODEL NO. WRT54G2VI
Star a new configuration of your router.To do it you must rest your router to "default factory settings" Here is how:
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Nov 23, 2010 | Linksys Wireless-G Broadband Router
I dont know my key or passphrase
Not sure what brand of wireless router you have but most have a system reset in the back where you stick in a pin to reset it to the factory settings, then you should be able to login without any password, this will completely reset the router so you'll need to setup security again if you had that setup before.
Jun 18, 2010 | Linksys WRT160N Wireless Router
Fogotten security pin
Are you trying to connect to the wireless network on a WINDOWS VISTA / 7 computer? Sometimes on the windows vista computer , it will ask you for the PIN number when you try to connect to the wireless network. On the same window at the bottom you will find the option " I want to connect to the network or I want to enter the key manually". If you click on that option , it will ask you for the security key.
If you don't know the security key, then you will need to check the settings of the router. You will need to open the router set up page where you can check all the wireless settings of teh router. If you want, you can also find the PIN on the wireless settings page of the router.
If you are trying to connect any other wireless device to the network and it is asking you for the PIN then you will need to open the set up page of the router and under wireless settings you will find PIN.
Click here for step by step instructions
Mar 10, 2010 | NetGear DG834G Router
Can not get my wii console to connect to my wireless router. It is a belkin and it keeps asking for a password.
To login to router setup page you need to connect the router with a ethernet cable to one of your computer or laptop then open a page of internet explorer and type in browser address bar http://192.168.2.1 and it will ask for username and password the username is by default "admin" and password is blank do not type anything in password and press ok you will go to the page of the router
  1. Then go to wireless settings and you can check what is the wireless security password, you can use the same to connect your wireless computer to your router to access internet wirelessly
  2. If you are not able to login to router setup page then you might need to reset the router from the reset button
Please let me know if this will help
Jan 06, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless n 150 router, pin worked for two laptops, third laptop keeps saying invalid pin/password but i am using the exact same one i used for the other two, anyone know why?
On any of the Computers that are Getting the Internet
Open RSP By typing 192.168.2.1 on the Address Bar of Internet Explorer
On the Left Side Under Wireless Click Wi Fi Protected Setup
Leave the Password Blank & Click Submit
Disable it And Click Apply Changes
On the Left Under Wireless Click Security
Take a note of the Password ( PSK Or Pre Shared Key )
Now on the third laptop Try to connect Wireless
It Will Either Ask For the network key or the Security
key Type The PSK
And connect to the Network
Dec 26, 2009 | Belkin (F5D7230-4) Router (587009)
Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
May 27, 2009 | Belkin (F5D7231-4) Wireless Router
Zonet (ZSR0104UP) Router Logo
74 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
