Question about Kenmore Washing Machines
My washer will nt spin fast enough to drain all water out of cloths.
    President:
  • 842 Answers
There's a good chance that the clothes are not spinning very fast BECAUSE they are too wet and heavy. The root of that problem is probably a blocked filter. I would suggest you check and clean your filter (Probably behind a door like the fuel flap on your car, situated in the bottom of the machine chassis).
Posted on Feb 02, 2010
  • 1294 Answers
SOURCE: whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Posted on Apr 25, 2007
  • 686 Answers
SOURCE: My Kenmore 90 serise washer leaves clothes wet. It
post your model number please
Posted on Apr 24, 2009
ltldab
  • 152 Answers
SOURCE: basket not spinning fast enough to drain water
FRONT LOADING OR TOP LOADING ??
Posted on Feb 26, 2010
SOURCE: Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Posted on Mar 30, 2010
rickyrt441
  • 4399 Answers
SOURCE: my washer doesnt seem to
Thanks for choosing FixYa and welcome. You do need to check the motor drive. Make sure the belt is not slipping or worn. That could be the case. It may be wearing out as you have suggested. You just need to get to it and determine the cause.
Posted on May 07, 2011
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Mayta mav275aw washer does not get all of the water out of clothes
The drain pump on those are fairly common to have problems...
It could be that the washer is not getting all the water out of the tub so the close stay wet. here's a link to the part:
Drain Pump 35 6780
It could also be that the tub is not spinning fast enough to squeeze water out of the clothes... Does it seem to bee spinning well?
Jun 11, 2014 | Maytag PAV2300 Top Load Washer
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
When in spin cycle does not drain all the water we have to hand wring all clothes
if all of the water does not drain could be the water pump or if the washer does not spin fast enough to wring the clothes could be a worn out motor or tansmission
Nov 17, 2009 | Office Equipment & Supplies
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Dec 29, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
