Question about Nikon FE 35mm SLR Camera
The exposure meter on my Nikon FE does not work properly. I have tried it in all kinds of different light, and the needles won't line up. Only the shutter speed needle moves. Can anyone help me?
  • kakima May 11, 2010
    Is the other needle stuck at the bottom, or is it somewhere in the middle? It doesn't move at all when you turn the aperture ring on the lens? Are you turning on the meter by pressing halfway on the shutter release?
Steve5
  • 423 Answers
SOURCE: Nikon FE
TRy firing the camera in the M90 setting. If it fires properly, use the battery test switch. If the battery LED doesn't light up, replace the batteries (2 MS76 type). The FE requires healthy batteries to operate the shutter. If the meter is calling for a slow shutter speed (low light or lens cap still on?). If the batteries are good, but the shutter still won't fire normally in sufficient light, looks like you're in for a repair shop visit.
Posted on Feb 18, 2008
SOURCE: Ricoh KR-5 light meter needle won't move, new batteries
In my case, I had the same problem, because the housing that holds the two batteries built up corrosive material. Looking at the little housing that screws out from the camera the two batteries' negative poles face away from the main camera and towards the inside of the housing. It is where the bottom battery contacted this housing where mine had packed on corrosion disabling proper contact.
I cleaned the contact points out with q20 lubricating spray on an ear-bud, and also cleaned the thread where it screws into the body of the camera. This solved the problem for me. Now I'm a happy chappy again...
Posted on Apr 22, 2009
Obertelli
  • 3006 Answers
SOURCE: Nikon Fe meter - warm batteries
If the batteries discharged sufficiently to become very warm in just a few seconds then there's an internal short circuit and the internal circuitry has almost certainly been fried beyond repair. To get warm so fast, those batteries will have shoved some significant current through circuitry designed to handle mere milliamps.
Your camera will be repairable using donor spares, but the repair will cost more than buying another fully functional FE especially when you add on the costs of the CLA (Clean, Lubricate, Adjust) service that it will almost certainly need and the likely need for foam light seal replacement. If you buy another FE it will also most likely need a CLA and seal replacement unless there's proof of it being recently done, but at least you won't have the additional costs of buying a donor FE, stripping it for parts and then doing a heart transplant on it.
On balance, yours is best used as a spares donor; you'll get some of what you spent back if you sell it as a spares/repairs example.
Sorry there's no fix, but I hope that you have still found my reply to be of some use. If so, please rate my answer.
Posted on Feb 22, 2010
Obertelli
  • 3006 Answers
SOURCE: Nikon FG Shutter and light meter not working
Sorry, but there is nothing else you can do without dismantling the camera and giving it a full service. It's not a DIY job so will have to go to a repair specialist.
Note that unlike some similar Nikon models of the time, the FG's complex electronics mean that your camera may now only be good for spare parts as it's likely that the main circuit board has failed and replacements simply are not available and arevery difficult and expensive to fit if you're lucky enough to locate one. The reputation for failure of this model due to ageing circuitry means that it's now unpopular and near worthless.
A repair specialist can certainly tell you whether the camera is repairable before undertaking any serious work on it.
Personally, I'd just advise you to sell it as is for spares or repairs and to obtain a working example or even the mechanical Nikon FM/FM2 which are still plentiful, easily serviced and repaired, and available fairly cheaply or even free (via FreeCycle).
Posted on Apr 08, 2010
Testimonial: "Thanks Obertelli for taking the time for the detailed answer. I am hoping to keep the 50mm lens and hopefully use it with adapter."
SOURCE: nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
Posted on Aug 31, 2010
Can I use one nikon d5100 with one sakar mc zoom 80-200 No. 803489
If your lens has a Nikon mount then yes, you can use it on the D5100. You'll have to switch to the Manual exposure mode and you won't get any exposure help from the camera's light meter.
May 31, 2012 | Sakar "Digital Photgraphy Macro Ring Light...
I would like to know if a 24mm Nikon f2.8 Ai Manual Focus Lens will work on a Nikon N75 SLR Camera
Yes and no. It will fit and you can take pictures with it. You'll have to focus manually, of course, and you won't get any exposure help from the camera's light meter. You'll have to use the camera in the Manual exposure mode, setting the shutter speed on the camera body and the aperture by turning the ring on the lens and, as I said earlier, without any help from the camera's light meter.
Mar 17, 2012 | Nikon N75 35mm SLR Camera
What settings do i need for rokinson2600 lense on my d5000 cheers paul
This lens lacks the electronics to communicate with the camera. You need to set the aperture ring on the lens to its smallest opening (largest f/number). You control the aperture from the camera body, the same was as on a lens without an aperture ring.
For the camera, you need to set it to the Manual exposure mode and set the shutter speed and aperture yourself. You also won't get any metering assistance from the camera. You can review the pictures and/or use the histogram to get the proper exposure, or use a separate light meter.
Sep 07, 2011 | Rokinon 6502600 f816 for Nikon
I am new user for DSLR, using old 50 mm 1.8 manual focus on D80, unable to see any inmage on playback (shows information). Will this lens work with D80, using settings as manual mode, f22 . Please guide...
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, as on a lens without an aperture ring. Turn the mode dial to M (manual). The camera's exposure meter will not work with this lens. You can use another lens to get an approximate exposure, or take pictures and review them and/or use the histogram to fine-tune the exposure. The camera won't autofocus, of course, but the in-focus indicator in the viewfinder will still light up to indicate proper focus.
Jun 17, 2011 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon FM film camera. The viewfinder has three exposure indicators visible within the viewfield: + for overexposure, O for correct exposure and - for underexposure. These indicators have...
If the red light is steady on the minus sign even if you vary shutter and aperture settings and point the camera at different light exposures, then this is a metering problem. If the red light on the minus sign turns off when you have correct or over exposure, then it would mean your indicator lights for o and + are busted. Have your metering checked by a competent camera technician. In any case, since your camera is fully manual, you can use the 'sunny 16' rule and still shoot away.
Feb 26, 2011 | Nikon Photography
When I attach my Lensbaby, I get a message saying "No lens". I know I'm attaching it correctly.
The Lensbaby does not incorporate any electronic circuitry. Without any, the lens cannot communicate with the camera. That is what the F-- message indicates. Without the communications, the camera cannot meter the exposure since it doesn't know what aperture the lens is set to.
Your lens is on properly. You just can't meter through it. You can use a separate light meter, meter through a different lens, or simply shoot and adjust the exposure by looking at the result and the histogram.
Sep 08, 2010 | Lensbabies Composer LB3N f?r Nikon Lens
Nikon EM (1979?) Won't wind film, photos don't come out
Not necessarily. The EM has an M90 setting which will fire the shutter at 1/90th of a second. The meter is inactive on this setting. It was put on the EM so that if the batteries fail, you can shoot at 1/90th and take a guess at the exposure. There is also a small button (blue or chrome, depending on the production run) which lights up a red LED if the batteries are good. The light meter doesn't work until the frame counter is at 1 or higher. Before the #1, the shutter will always fire at 1/2000th of a second to speed up the film loading process. You can tell that the meter is working by observing the meter's scale/needle on the inside of the viewfinder. If it is pointing out of the red zone, it's OK to shoot (proper exposure). If the needle is in the red zone (indicating under or over exposure) the camera will "beep" as an audible warning. Check the battery condition first.
Mar 16, 2009 | Nikon EM 35mm SLR Camera
Nikon FE
Feb 11, 2008 | Nikon FE 35mm SLR Camera
Nikon fg light meter
Ah, I figured this out. It's not the battery, since the light isn't dimmed. I had the same problem with the light being stuck at 60/120, and it was just flashing. There's a certain mechanism in the camera that only allows the light meter to start working when the exposure count is at 1. So when you load your film, you have to take 2 or 3 exposures, and crank it, before the light meter kicks in.
Oct 27, 2007 | Nikon FG 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
1,279 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
