Question about Acer PD100 Multimedia Projector
No Signal Acer PD100PD DLP Projector No Signal.....Is there a driver for this Projector? I used the USB port and the serial port and neither work Any suggestions will be much appreciated Regards Ian
  • 4 more comments
  • Anonymous Aug 20, 2008
    No input from the HP notebook
  • technees Aug 20, 2008
    the projector does not read the HP notebook for display, it was working properly before AVG antivirus was installed
  • chelimohapi Sep 18, 2008
    No signal after the installation of AVG antivirus
  • Anonymous Dec 18, 2008
    projetor nao esta recebendo o sinal
  • Anonymous Mar 13, 2009
    No signal
  • Anonymous Mar 29, 2014
    install projector on my Asus laptop to be connected via the USB port
I wanna try to change into 75hz, but there is only 60hz available. what should i do? my acer pd1100 projector won't display the pict from my laptop :(...
Posted on May 16, 2008
Try it with 75Hz for the second monitor and use the VGA input.
USB/serial is only for configuration.
Thomas
Posted on Mar 21, 2008
Acer d257 usb port not working
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
hope this helps
Jul 24, 2012 | Acer Aspire One D257 Netbook
How to connect Acer X1161 3D DLP Projector via USB
1-i have some dots like pixel damage so i need a solution for that
2- i need to connect via usb cable but i cannot connect
thanx
Jan 26, 2012 | Acer X1161 3D DLP Projector
Getting 'No signal ' response. What could be the reason?
try using a lower screen resolution on your PC,
Try checking that the signal you are sending to the projector is actually there
Apr 08, 2011 | Acer X1230 DLP Projector
How do i get sound from my acer x1230 projector?
The acer x1230 projector has an audio mini-port on the back.
In order to utilize the speaker in the projector you will need to run a cable with a mini plug (same as your standard headphones) from your source to the projector.
On a side note, I would suggest using something else for your sound. Data projector speakers are akin to the internal speakers on a computer. The sound quality is not the best and the speakers on data projectors tend to not stand the test of time.
Your basic desktop computer speakers will give you better quality sound and they will most likely be louder as well. In addition, they use the same kind of port (mini) that you would use for the projector input.
Mar 02, 2011 | Acer X1230 DLP Projector
I connect it to my MacBook Pro using a USB cable but it doesn't communicate
You can't use a USB port for a projector, unless the video bit rate is extremely poor.
you will need to use hdmi, dvid, or thunderbolt
Jan 26, 2011 | Acer PD523 Multimedia Projector
Acer 4736 compatibility with eb-s6 projector in usb display mode.
Check the Microsoft knowledge base for a "workaround" for this issue.
Try doing a search for "device not recognized" there should be several steps to correct this issue. However this may be due to compatibility with your projector and the usb port drivers. Contact the manufacturer or go to his website for driver and usb information on your Projector ability to connect to your Acer. Good luck!
Aug 13, 2009 | Computers & Internet
No signal or loses signal from computer
Keep the computer on when you plug it it
so have the computer ready
May 12, 2009 | Acer PD725P DLP Projector
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
DRIVER FOR WINDOWS VISTA
www.acerpanam.com/synapse/forms/acerdrivers.cfm
Jun 26, 2008 | Acer PH110 Multimedia Projector
Acer PD100 Multimedia Projector Logo
1,607 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
