Question about GE Monogram ZDP30N4D Gas Kitchen Range
Has gas and ignition on but no fire start. - GE Monogram ZDP30N4D Gas Kitchen Range
  • 619 Answers
If in oven change the igniter , not producing the amps needed to open valve.
Posted on Feb 02, 2010
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Igniter Works, but Gas won't fire up on Sensor Dry, Will on Timed Dry
PLEASE do not use this dryer until it is fixed. it may be a saftey hazard. From the sounds of it. Your ignitor is only getting a signal every now and then. Now either is a coupler in there to tell the ignitor when to fire and when not to fire. It seems that it is going out only alloweing the dryer's ignition to come on only when a new cycle is started. That is where i would start... check with an appliance repair shop and find out if it will be something you can do your self or if it is something they have to do....
Now I do STRONGLEY recomend that you have a service technicion come on and service your dryer do to the fact that it is a GAS dryer. if something inside the dryer where to get pinched or broken it could cause a bigger problem....
so please take this advisment under consideration....
Thank you.
Aug 04, 2008 | Whirlpool GGX9868J Gas Dryer
Ignition stop firing/engine floods w/ gas
Check for loose connections on your ignition system, mainly around the coil.
Jan 07, 2013 | 1993 Pontiac Sunbird
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
I have an archer aurora gas fire and even tho the control box has been serviced and we have mains gas, we still can't get it to light-the ignition will glow but then go out before starting the fir
see the video for test the igniter
2)Test the Sensor + coil for continuity otherwise is defective, this cause to shut off the flame! and replace see how.
Jun 09, 2012 | Dryers
MY DUCANE FURNACE FIRE TOO HARD ON IGNITION
Gas pressure may be too high. you need to check the pressure at the regulator. 3.5in. wc for natural gas and 11.7in. wc for LP gas. sometimes when the system does not purge the gas vapors with the draft induce blower, when the ignition starts it will fire hard because of the excess gas vapor found in the burner chamber. hope this helps you out.
Nov 27, 2010 | Heating & Cooling
My 2003 sunfire wont start its getting fire and gas and it turns but wont start why
Please consider following matters:
1. Ignition. Blue color fire is the the best ignition power 2. Gas. Check your fuel filter and injections 3. Compression. Combustion chambers should have enough compression to start the engine. Does your car lost its compression? Is the car has blue smoke on exhaust muffler ? Do you need top up oil regularly? All these things show your car has problem with compression.
Nov 26, 2010 | 2003 Pontiac Sunfire
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Kenmore elite gas dryer won't heat
Presuming that you checked the obvious gas flow. It is most likely 1 of 2 problems. Most likely the electric igniter is burn out or cracked. when the unit is turned on it will glow red hot and then tell the gas valve to start the gas flow and then you have fire. BUT 2) if the roll out limiter switch lies to the machine and tells it 'Hey the fire is out of control! Shut off the gas' it will never open the gas valve to start the fire.
IF the igniter is cracked you may not see it. It simply won't work. If the roll out limiter switch is broken you definitely will not see it broken.
Both problems are common. Neither have a way of testing with a multimeter if they are good.
The third and very, very rare is the control console is broken. I would check to see if the glow igniter is working first.
Mar 17, 2010 | Kenmore 62602 Electric Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
GE Monogram ZDP30N4D Gas Kitchen Range Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
