Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
My safe box low battery and i dont have the key
I cannot get n my safe. I cant find the key n I think the battery is low.
I would suggest leaving it for a day so that the battery has some power (they do recharge slightly if not completely dead) and make sure you get the number right straight away. You really need the key to be found, as it makes it so much easier. You may still have problems with a new battery; this is what we have found in the past. Good luck.
Apr 17, 2014 | Safe International Electronic Digital...
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions...
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions from the internet anywhere? The keys have 128 written on them but I cannot find any further I.D numbers anywhere. Thankyou very much for your assistance
May 21, 2011 | Safe International Digital Electronic Safe...
Micromark safe lost my keys. can i get a replacement key?
If the battery power has fallen too low the safe will revert to it's factory setting 159A or 159B if you have enough power to make the unit work one of these will open it.
Oct 27, 2009 | Safe International Digital Electronic Safe...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Can not open nu tool sf 10 electronic digital safe
If the batteries are flat you will need a key to open your safe, the keyhole is usually under a plastic cover on the front of the door.
If the batteries were getting low a light should have warned you.
Hope this helps.
Mar 05, 2009 | Computers & Internet
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Low battery
Dont know your model but on mine the battery is located behind the key pad. turn it clockwise and pull it strait out to access battery.
Mar 29, 2008 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
212 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
