Question about Onkyo SKW-200 Subwoofer
No sound coming out of my Onkyo SKW-200 subwoofer
I recently noticed no sound coming out of my SKW-200 subwoofer. The standby light on the front of the speaker was red. I messed with a few things - disconnected and reconnected the speaker wire both at the back of the speaker and the back of the amp (even tried connecting a different cord), disconnected and reconnected the power supply to the speaker, pulled the circuitboard and checked the fuses (they both were fine), made a visual check of the various electrical components on the circuitboard and couldn't find any obvious visual defects (scorches etc.) and have never noticed any type of burnt odor, cycled through about every combination of "subwoofer mode", "speaker mode", "audio adjust" etc. During these primitive review processes, on a couple of occassions, the standby light on the front of the speaker turned green, but it now remains red. If anything I have baby'd my system and really never played it louder than 65, and not for extended periods of time above 55. I am super frustrated at the loss of the bass of my system and would appreciate any additional troubleshooting tips anyone can provide.
  • Onkyo Master
  • 5,154 Answers
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Posted on Feb 02, 2010
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
The amp output stage or the power supply is shorted. Service shop type repair.
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
Onkyo sks-ht540 subwoofer
Sounds like power problem of some sort ,have you read the instructions properly.some of these will have on/off switches in the wierdest of places
May 25, 2007 | Onkyo SKW-200 Subwoofer
Onkyo SKW-200 Subwoofer Logo
1,524 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
