Question about Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer Super Jolly Manual
Ive bought a secondhand Mazzer Super Jolly and want to give it an overhall,
I need to get hold of a manual, engineers handbook.
Any help appreciated.
  • 1 more comment
  • Jean Morrison Mar 02, 2008
    Need to get a super jolly manual
  • Bigjohn15668 Apr 11, 2008
    I'd like an instuction book also!
  • Anonymous Jul 12, 2008
    same here... bought a used SJ in excellent condition for $20.00.  Yes, twenty dollars.  Was missing the manual, hopper and lid.  Not bad....huh.
Check out this link for the Super Jolly manual:
http://www.wholelattelove.com/manuals/Mazzer/Super%20Jolly%20Product%20Manual.pdf
Posted on May 21, 2008
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
Just bought a mazzer super jolly grinder, used it once, the grind was too coarse (#6), adjusted it to a finer grind ((3), and the next time i ran it it stopped grinding, the motor is on, the grinder turns,...
yes, you have to remove the beans inside because there is beans stuck between the burrs. after removing the beans, start doing the finest first before loading the hopper then after putting the beans test the grind as you go courser.
Feb 11, 2012 | Mazzer Coffee-grinder SUPER JOLLY Electric
My super jolly mazzer grinder is switching off after only a few seconds grinding. used to grind continuously for however long i needed, now i have to turn it on 4-5 times just to get enough for one shot! ...
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
ukeboy57
Nov 07, 2017 | Mazzer Coffee-grinder SUPER JOLLY Electric
We have a Mazzer Super Jolly grinder and we can not get the dosing lever to move without pulling very hard while holding the machine with the other hand. Please help.
your doser mech is possibly gunked up with old grinds, first off try stripping it and cleaning it out, if that doesnt work you may need a new return spring but i think its far more likely to just need a good clean. this is from the mazzer mini but the doser design is pretty much the same so it should help you with disassembly
http://www.home-barista.com/grinders/mazzer-mini-component-photos-t3577.html
May 09, 2011 | Mazzer Coffee-grinder SUPER JOLLY Electric
How do I adjust the doser knob?
in the center of the star you have one screw and black knob, Release screw, adjust with black knob, than screw it back to prevent moving of knob
Jan 20, 2011 | Mazzer Coffee-grinder SUPER JOLLY Electric
Hello. My Mazzer grinder doser Super Jolly (used
It could be that the switch failed, try this to check remove the top part or the grinder burrs and turn it on, if it turns then, grinder was jammed if not switch needs to be replaced.
Apr 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer Coffee-grinder SUPER JOLLY Electric Logo
2,883 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
