Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
When new filter was put in the light did not go green but instead was red, what does this mean
  • 254 Answers
U must reset that filter indicator light all are differnt on hoe u do this,, if you do not have ur manual go online to frigidaire and locate a manual on their site which will tell you how to reset that light..
Posted on Feb 02, 2010
2 Suggested Answers
SOURCE: How to change the water filtration light from red to green?
you just need to push the check filter button 4 or 5 times and it will reset the indicator light -mech7364
Posted on Aug 08, 2009
Green alarm light continuously on. Any ideas?
Green light usually means your water filter is in great condition . the light will stay on,over time change to amber then red. Red means change filter
Jul 22, 2015 | Refrigerators
What does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here http://www.zyxel.com/uk/en/products_services/pla_401_series.shtml
Jul 16, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
On mine, there is a button combination that resets the alarm. Yours may be different. The bottom buttons, one left, the other on the right. Mine say "ice type" and "child lock". Holding them both in for ~5 seconds resets the alarm. Try this.
Best regards, --W/D--
Aug 08, 2009 | Kenmore Refrigerators
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
