Paper Jam Error
I just cleaned the fuser unit on my AL-1642CS printer, which fixed a major problem I was having. However, I now have a paper jam error. Is there a sensor in the fuser unit that I might have disrupted while cleaning? If so, where? Where are the paper sensors located in the rest of the machine?
  • cassiecat4 Feb 05, 2010
    Joel - Thanks for responding. But can you be more specific as to the location of the sensor? Do you happen to have a schematic? Or know where I can find one?
  • 155 Answers
Yes i think there is an exit sensor. most of the sensor are located in their exit sometimes most are made of micro switches and maybe you knoked out their position
Posted on Feb 04, 2010
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
Please Help!!!!!
The fuser has a flag sensor with an arm that the paper hits as it passes through. That arm moves a flag at the other end that hits a photointerrupter. You may have broke this. If so, you will likely need to order it through a dealer.
Feb 04, 2010 | Sharp AL-1642CS Copier
Printer says jammed , cleared printer completely, still says jammed , no evidence of jam,disconnected printer, reconnected, ,still says jammed,
The possible reasons for this could be
  1. (For Laser Printers Only) Toner sediment in the fuser unit. This specially occurs if you constantly use smaller paper sizes than the paper tray size. To resolve this you should disassemble the printer, take out the fuser unit and clean the toner sediment. The sediment can get rock solid so clean it carefully. If you are not accustomed with electronic components better visit a technician.
  2. The paper sensors pulling spring may be detached. In this case the sensor gets a message that some paper exists in the fuser unit so a paper jam message is triggered. Fix the spring and you are done.
Nov 27, 2009 | Office Equipment & Supplies
Paper jam light on
the censor that detect presence of paper in the printer has stopped working. check it if you can or get it repaired from local sevice centre......
Sep 29, 2009 | Sharp AL-1217 Copier
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Jan 06, 2009 | Sharp AL-1642CS Copier
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
57 people viewed this question
k24674
jasbo
jasbo
