Question about Olevia LT32HVM 32 in. LCD Television
My Olevia 532-B13 won't auto scan channels. I can punch them in on the remote keypad but cannot use the channel function on the remote nor the TV. Any ideas?
SOURCE: I cannot get my Olevia 226 T11 to do an auto
Check the Power Up setting to be sure it is starting up in HOME mode rather than SHOWROOM mode. In showroom mode, many settings cannot be changed.
Posted on Feb 15, 2010
SOURCE: Suddenly the Tuner mode reports "No Signal"
Just a solution.
I attached a video recorder., and selected the video channel.
I was able then to see the channels through another AV slot extension.
Then I reset the TV to factory settings.
Samsung full HD reset code is 0000.
I used the original remote control.
I pressed the button TV/DTV to switch between mode., and from the menu I started
the option to scan the channels automatically.
Because the VCR was still connected it looks like it was forced to admit the channels.
I turned off the VCR and click on the TV the remote control for a known channel ( alternative control used) and surprise ... The TV started to react according to expected.
I disconnected then physically the cabling from the VCR and plugged in directly on back on the
wall connector. All is ok.
What was the reason ?
My wife dropped the alternative remote control ( not the original one) on the floor, and apparently an strange code was sent to the TV., which suddenly displayed " No signal".
I hope this can work for you.
Kind regards
Sanchez
Posted on Dec 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
SOURCE: Channel selector does not work; can not auto tune
Sorry not be able to solve the problem. I have exactly the same problem. So it is not related to anything you've done. Something faulty in the TV. It happened after 1.5 years in my case. Any tech support link appreciated
Posted on Jan 12, 2010
After AIR setting and AUTO SCAN, I cannot even receive local channels 4-5 miles away. What is the problem? See below for details.
There may be a problem with the antenna connection. Channels are not being sensed during the scanning process
Dec 12, 2016 | Olevia Televison & Video
How to reset the parent control on my Olevia 532H
Check this link to download the user manual to your TV. It has all details.
Oct 15, 2012 | Olevia SC0-P605208GMM2 Main Board for...
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
May 13, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia lct tv can't do a channel auto scan
first check the batteries in the remote to make sure they are not low and then have the remote tested most repair shops do it free.
Mar 14, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Apr 22, 2010 | Syntax Olevia 532H 32 in. LCD HDTV
OLEVIA LCD TV: can't get setup to auto scan air channels
worked for me thanks. Don't know how it go in the showroom mode?
Oct 16, 2009 | Televison & Video
Channel Search
With remote, hit MENU, (use up/down arrows) & scroll to SETUP. Hit ENTER & scroll to TV. Hit ENTER & scroll to AUTO CHANNEL SEARCH. Hit ENTER & scroll to CABLE. Hit ENTER & scroll to AUTO. Hit ENTER, wait as it scans (about 5 min). Your done.
Jun 18, 2009 | Televison & Video
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Just a solution.
Kind regards
Sanchez
Aug 21, 2008 | Televison & Video
Olevia LT32HVM 32 in. LCD Television Logo
550 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
