Question about NetGear RangeMax WPN824 Router
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut down and restarted could not pick up the router again, also only was able to pick up only two bars, I read that Wireless-G was compat. with the wpn824v3, the new desk top is running with the new windows 7. How can I get more bars. Could I upgrade the usb adapter? and to which one? would the wireless-N 300 or rangemax adapters be better
  • 12 Answers
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Posted on Feb 19, 2010
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear Wireless Router and NewGear WG111 Adapter
I imagine you bought the WG111 Kit. It could but throught the Router and/or the adapter. Uninstall all netgear software and drivers. Unplug the adapter. Reboot machine. Plug the adapter in and install the software drives. Basically your starting over. This will take the quess work out of trying to repair what was lost. After reinstalling go to this web page to configure the SSID,IP and adapter. http://kbserver.netgear.com/kb_web_files/N101179.asp
Jun 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 doesn't see D-Link DIR-655 wireless network
Hi Joe,
I would suggest you to change the wireless channel on the Dlink and use the channel on which WG111 will scan and connect to your network. Also, plese make sure to use the security encryption on the DLINK to WEP or WPA only. Using higher security like WPA2 will cause issues with this adapter.
Regards
Anand
Jun 21, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear range max will only part load on to my desk top
check u are enter as administrator.
also try to use another usb.
check that your usb port working fine.
Nov 10, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Stupid router
SUE NETGEAR PURPOSE OF WIRELSS ADAPTER IS TO CONNECT WIRELESSLY, IDIOTS
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Low signal so cant get internet 52 mbs adapter
you can increase the RX-TX power of your router. Some routers come with option that you can increase the range of them not. However Open source solutions are doing well like www.dd-wrt.com depends on your router it can cascade the the range many times. Alternate solution is to get 2X - 4X Range WiFi adaptors that can be extended by booster antennas. Good Luck
Feb 06, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Jan 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear RangeMax WPN824 Router Logo
212 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
