Question about Toshiba Satellite A45-S120 Notebook
Cursor froze on my toshiba lap top model L505D. Tried FN-F9. Still won't work
    Genius:
  • 1,189 Answers
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select the "Mouse". In the Mouse, "Properties" (window) change mouse functions.
Posted on Feb 02, 2010
Brand new Toshiba Satellite L750 series. Cursor is locked Keyboard is locked How do I unlock the cursor. I've tried switching off 10s then on and starting normally. No good
Hello there,
Drivers and Manual Link
Try pressing, Function key + F9..
F1= Lock Computer Mode F2= Change Power Settings F3= Change to Sleep Mode F4= Change to Hibernation F5= Switch Active Display F6= - Brightness F7= + Brightness F8= Enable/ Disable Wifi F9= Enable/ Disable Mouse cursor
About the keyboard lock? I have no idea, because most laptops have cursor lock only. Correct me if I'm wrong. Hopefully this helps.. Thank you for posting..
Jul 12, 2011 | Toshiba Computers & Internet
I can move the cursor but the click dose not work on my toshiba lap top could u help make it work i tryed to us the f 9 key but dou have to do somthing elseafter pressing f9?
I would use a USB mouse to get into the control panel, mouse properties and check that the buttons are enabled. If that does not work you may need to download and update the driver from Toshiba's web site, located here.
Jul 11, 2011 | Toshiba Satellite L455DS5976 Notebook
I have a L505 Toshiba lap top does It have a lighted key board? I've heard yes and no if yes how do you get it to work?
For you to check if it has a backlit keyboard press Fn+Z or go to start/all programs/mytoshiba/utilities/HW setup/and there should me ilumination option. If none of this works, it only means that your laptop does'nt have that features.
Mar 18, 2011 | Toshiba L505D-S6947 Notebook
Cursor is frozen, tried allsorts to solve it. Nowt works. Using mouse with usb cable, works fine. Synaptic logo from bottom right of screen also gone. Tried system restore and it works until I log on...
Sounds like a driver issue with the touch pad. You should try and reinstall the driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998675&rpn=PSLB1U&modelFilter=L300-EZ1004X&selCategory=2756709&selFamily=1073768667#
follow that link..it will take you to the driver page for your model laptop.
Mar 07, 2011 | Toshiba Satellite Pro L300-EZ1004X...
I am not able to connect through internal wifi(wireless) network device in my Toshiba Satellite L505D Laptop. I am able to connect net through a external USB wireless network adapter.What is the problem...
Locate the wireless switch and turn it on? if it is on you might need to reset the modem from your service provider. Just go and hit the reset button on the modem or turn it off completely. Power it up again and make sure that the switch is turned on if you have one for this lap top some are automatic.
The switch is usually located on the left or right front of the lap top housing in the front or on the keypad. You may have to push the FN key if the key is blue highlighted. Hit FN and press the wireless key if applicable. Make sure all is on and switched then reset the wireless modem or connection.
Jan 28, 2011 | Toshiba Satellite L505DGS6000 Notebook
Turned on the computer, the mouse/cursor froze; removed battery pak; didn't work; tried FN F9, didn't work; what now?
I'm assuming that you have tried all the F8 boot options and none worked.
If the keys don't work then the hard disk is completely corrupted - if you're unlucky its because the hard disk itself failed. You probably will need to boot in the BIOS (F12 during start) and set it to boot from USB. Then find a USB cd-rom and use it to boot from a Linux Live - CD: use it to find out if the hdd is still functional. If it isn't then you will have to replace it , then reinstall Win 7 using a disk that you can borrow from a friend and your key.
Nov 27, 2010 | Toshiba NB255N245 Mini Notebook
MY Toshiba satellite L505D-GS600 laptop TouchPad is stop working, and I already tried Fn and F9 but did not work.
Press Shift key 5 times, and then go to settings, uncheck "Use stickykeys" "use filterkeys" and "Use togglekeys", to do this, use tab key, arrow keys and space to uncheck. Apply and then "Ok. Good luck. Thanks for using FixYa.
Jun 01, 2010 | Acer Aspire 5610-4648 Notebook
Frozen Cursor
Have you tried pressing <FN><F9>
May 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A45-S120 Notebook Logo
132 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
