Question about Fellowes DS-1 Shredder
WILL NOT SHRED FORWARD ONLY BACKWARDS - Fellowes DS-1 Shredder
This sounds like a switch problem. We know that the motor works and the gears are okay when the shredder will work in reverse. That leaves the main power switch and the paper sensor switch in the feed slot. Failure of either of these switches can cause your problem. It probably is not the safety switch requiring the bucket to be in place since this switch needs to be activated for the shredder to work in either direction. The sensor switch is probably a standard single pole normally open micro-switch but the main switch is another matter and would probably have to be purchased from Fellows. Anyone with electronics experience can probably disassemble the shredder and replace the switches. If the problem is the main switch, I would recommend replacing the paper sensor switch while I am inside the guts of the thing. Even if you have to take the shredder to a shop, I think the cost should be significantly less than replacing this shredder. It's at least worth checking out.
Posted on May 08, 2014
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 02, 2010
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
Will not shred no matter what I try to do. I have run it backwards and forward and it still will not shred. Please advise and thank you.
If you want to keep it , I think you should dismantle it make a mental note of how you do it, free any paper jam and spray the cutter blades with a thin layer of WD 40 or similar then you should be good to go unless the motor is burned out from you constant on off testing
May 25, 2015 | Royal VF1700MX Shredder
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
The schredder runs backward, but forward does not.
Take care, because this thing can also shred your fingers.
Remove the plug from the outlet and try to remove the paper under the rolls. Us a tool, not your fingers. It even would be better, if you could put the top upside down, so you could see where the bulk of paper is clothing the wheels and the sensor.
I think you already emptied the bag under the shredder, because the paper full sensor also prevents the shredder from running forwards.
Jun 16, 2014 | Intimus 421 SE Shredder
I INSERTED A THICK OBJECT INTO MY FELLOWES SHREDDER. SOME WAS SHREDDED-HOWEVER MOST OF IT IS STUCK IN THE TEETH OF THE SHREDDER. i HAVE TRIED EVERYTHING-BUT NOTHING WORKS. HELP1
I did that in my shredder and had to use the backwards option for a long time...forwards then backwards and pulling out the material little by little. It is a slow process...you can sometimes pry it a little but make sure you don't insert anything while shredder is operating. I always unplugged mine when trying to tug the stuck paper out of it. You don't want to take any chances. Good luck!
May 04, 2011 | Office Equipment & Supplies
Hi My PC Line shredder goes backwards as long as I want but will not go forward long enough to shred one sheet of A4.
If your shredder has an auto sensor "eye"to start it up automatically, check that it is clean you will see two windows near the paper mouth- give them a clean first thing. if not migvht be a switch or a burnt out motor in the forward direction ( or control circuitry)
Hope that helps
Jan 16, 2010 | Office Equipment & Supplies
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fellowes DS-1 Shredder Logo
416 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
