Heater blowing cold air only
I have a Ford KA and the heater is only blowing out hot air.
  • David36 Feb 22, 2008
    Tried moving to cool but it makes no different. Have checked levels and all appear OK.
    The problem is that no matter what setting it is on only hot air is blowing out.
It's almost certainly the heater control valve, which is mounted between the engine compartment and the plenum chamber (i.e. the area under the black plastic at the base of the windscreen). The valve is controlled by the temperature knob on the dash and has two rubber pipes going into each side of it (hot and cold) The part costs about £30 and all you need to fit it is a crosspoint screwdriver, a 10mm spanner and a pair of pliers, but access is difficult because you have to remove -- in this order -- both windscreen wipers, six rubber plugs and screws securing the black plastic trim, radiator header tank (just enough to tilt it forwards out of the way), three screws securing windscreen plastic to plenum chamber plastic, single screw securing both halves of windscreen plastic, three screws securing plenum chamber plastic to the body.
With all this out of the way, disconnect the wiring plug on the heater control valve, use pliers to remove the spring clips, pull out the two rubber hoses on each side and then remove the old part. Reassembly is the reverse of removal but DON'T forger to plug in the electrical connector. There's no need to drain the radiator because only a cupful of water wil be lost. Use an old towel to stop it getting everywhere.
Posted on Apr 18, 2009
Hey, David,
have you solved this problem yet?
Did you try moving the vent adjustment to cool position?
Please explain what you have done so far.
Posted on Feb 22, 2008
  • Anonymous Feb 22, 2008
    What is the real problem here? Is it cold air only or hot aair only? Look at your problem label and your reported problem.
    Generic problem for all System Cooling
    David,
    My expertice is computer science, but I bet your cold air main cold air hose is blocked somewhere near the mixing point; that is where the vents seperate air before it reaches the fan. That is really a mechanics job now to open there and check. It's gotta be blocked by something.
    Good luch
2 Suggested Answers
campus
  • 56 Answers
SOURCE: HEATER FORD KA
your heater hose may have a leak or a blockage, preventing the hot water circulating. Pull off the heater hose and flush it out. Heater hose generally goes from your radiator T junction to the firewall of the vehicle.
Hope this helps
Posted on Dec 05, 2007
Heater not working
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | 2001 Ford Taurus
Hi the heater on my Ford KA is only blowing out cold air even when turned to hot on the control knob. I recently had problems with it blowing out only hot air all the time and had a new solanoid fitted but...
Sounds like whoever did the repair work did not install the solenoid correctly or did not reassemble everything properly. If you had heat prior to the repair, the heater control panel must have been working. The mechanic must make a better diagnosis than this.
Oct 14, 2010 | 2001 Ford Focus
55 plate Ford Ka, heater only blows hot
Check the temp dial, the potentiometer may be faulty
Nov 09, 2017 | Ford Cars & Trucks
My heater in my Ford KA 1999 has stopped blowing hot air and now only blows cold air. A friend has suggested it might be a fuse, just wondering if anyone knows where the fuse box is or any other...
Fuse box is behind a panel under the dashboard on the steering wheel side. Heater solenoid is #12 I believe.
A cold heater is most likely a bad solenoid valve. This pulses off and on to give the required water flow into the heater matrix. It seems a common fault that this solenoid fails or the valve itself gets blocked. Ford parts are expensive (£50?) and scrap yards don't seem to have them. A competent DIY'er can do the job in about an hour if they have the replacement part. Requires taking off the cover between bonnet and windscreen and grovelling down behind the bulkhead (apparently). I know all this 'cos I need to do the same - my daughter's Ka has the same problem!
Dec 28, 2009 | Ford Escape Cars & Trucks
Cold air blowing from heater in my ford ka
this is a common fault. heater control valve faulty under scuttle pannel how to test .turn heater control switch half way between hot and cold with fan blowing then touch the valve if it is[ pulsing] ticking then faulty 100% sure this is the problem
Dec 18, 2009 | 2003 Ford Escort
2005 KA blowing hot air out when set to cold
start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
Jun 24, 2009 | 1999 Ford Taurus
Ford ka blows hot air even set at cold
sounds like heater control valve situated under scullle panel common fault on ka set heater fan switch half way between hot and cold with heater blowing then touch valve if pulsing or clicking noise it is faulty if doesnt solve problem faulty switch
Jun 07, 2009 | 1999 Ford Taurus
Ford ka heater blows hot air all the time
Your problem is a faulty heater control valve. The design used on these vehicles allows for hot water to flow constantly and compete with the evaporator as there is no blender door. You have to replace the valve and possibly the control head. Meanwhile, you can bypass the valve to have cold air
May 31, 2009 | 1999 Ford Taurus
Taurus does not use a heater control valve. It runs coolant thru the heater core constantly. You may have a temp blend door actuator problem or a plugged up heater core is also very common. Feel the heater hoses, they should both be very hot, it one is much cooler; you can try to back flush the core.
Mar 26, 2009 | 1999 Ford Taurus
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
