Question about Samson Resolv 65a Main / Stereo Speaker
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
  • Samson Master
  • 5,151 Answers
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
Posted on Feb 02, 2010
Samson 65a: power good, speakers good , LEDs lit, no sound at all?
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 11, 2016 | Samson Resolv 65a Main / Stereo Speaker
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Jan 04, 2015 | Samson Audio Resolv 65a Active Studio...
The left tweeter from my Mediaone 5a monitors is not working
Have your tried switching the speakers to make sure the lack of high frequencies travel with the speaker?
Mar 08, 2014 | Samson Mediaone 5a Active Monitors
Infinity tweeter
okay ill answer this as best to my knowledge.There inside is a wire going to the woofer or the low frequency speaker.then you have the tweeter which is for the really high frequency.Inside there is either a capacitor or a crossover a capacitor is a small can looking piece and the croossover is a coil or wires.But what this does is stops the tweeter from receiving the low frequenies that should be directed to the woofer as it also stops the woofer from getting the high frequencies.You need to open it up and see if any wires are loose or disconnected or if anything dont look right if there is a capacitor look on the top and see if its buldging if it is it is about to pop which that could be your problem or it may have already.Do this when you open it up will you tke a video and show me the inside of your speaker.
Mar 17, 2013 | Samson Resolv 65a Main / Stereo Speaker
65a Resolv studio monitors. The left one just blew out -- maybe. The blue LED stays dim, as though the monitor has been sleeping. When I power off the monitor, the speaker gives a loud pop, and the cone...
You are getting DC offset voltage on one of your amplifiers that is the reason the speaker pushes out and you might be hearing a humming noise too. Do not turn on the speakers till you get it fixed or else you would end up burning the speaker voice coil too.The dim blue LED is also an indication of a short circuit in the output stage.
Your left amplifier needs a output chip (IC ) replacement. You will need professional help to do that. Will cost you about 20$ plus service charges.
Jun 27, 2011 | Samson Resolv 65a Main / Stereo Speaker
Tweeter is cutting in and out
need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
Jan 04, 2011 | Samson Resolv 65a Main / Stereo Speaker
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
Tweeters will not put out sounds, they do not look blown.
You need to go inside and isolate the tweeters. Then with a 1.5volt battery apply the + to + etc for a second. If it pops it's working and the problem is in the crossover. If not it's dead!
Feb 23, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a monitor repair
Its prob a dry solder joint problem.
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html
Jan 14, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a Main / Stereo Speaker Logo
803 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
