Question about HP Pavilion dv9000z Notebook
Screen cracked pc was knocked off the table(tripped over the power cord) and the screen appears shattered its the best way to describe it
    Brigadier General:
  • 4,044 Answers
You can open this up and replace it yourself with a small phillips head screw driver and a little patience. Your best deal for a replacement screen will most likely be from Ebay but you can order it from HP. You can replace just the screen or possibly get a whole top cover assembly on ebay. You'll need to pay attention for screws under covers that are not apparently covers and under some stickers on the bottom side of the computer. Also pay close attention to where screws come from as they very in length and in order to get the computer back together you'll want to get them back in to correct locations. If you don't feel you can do this replacement on your own my best recommendation would be to just buy a new laptop as a repair shop will most likely charge somewhere around $800 to do the job and a new PC can be purchased for about the same price. You can remove the hard drive from the current computer and install it in a new one allowing you to recover any files you may have saved on that drive. For that matter you could set up a dual boot option using a third party boot program to allow you to boot to either the new computer operating system or your old system if you wanted. It all depends on how much time you want to spend on the job or how much you want to spend. Good Luck.
Posted on Feb 02, 2010
Skill saw table saw model 3400.Bypassed on off switch still no power?Does motor have a breaker on inside?
I have the same saw.
Sorry but this question has to be asked, is the AC (Alternating Current) outlet working/ an live outlet? Had to ask.
If outlet is good move on to the next steps.
Take an ohm meter / continuity meter.
With the AC power cord unplugged from the AC wall outlet.
Place the two test leads from the meter onto the plug prongs .
With the switched closed/ON, you should get zero ohms (or very low, close to zero/ continuity).
In your case you probably will not have any continuity because it doesn't turn on.
Now comes the fun part trying to find the problem/ open connection.
Lots of possibilities.
  1. The AC cord could be bad at the plug end.
  2. The AC cord could be bad at the point entering the table saw.
  3. The motor could be bad.
  4. The brushes in the motor could be bad.
  5. The field winding in the motor could be open/bad.
The plan is to ohm/continuity check the path of the power going to the motor, (both sides of wiring).
While meter leads are on the AC plug end, wiggle the strain relief ends. You have an intermittent connection.
TROUBLE: SAW WILL NOT START
PROBLEM 1. Power cord is not plugged in.
2. Fuse or circuit breaker tripped.
3. Cord damaged.
4. Burned out switch.
REMEDY 1. Plug saw in.
2. Replace fuse or reset tripped circuit breaker.
3. Have cord replaced by an Authorized Skil Service Center or Service Station.
4. Have switch replaced by an Authorized Skil Service Center or Service Station.
May 25, 2016 | Saws
Screen of portable dvd player is "bleeding"
Sounds like the LCD is leaking liquid crystal. If you contact the manufacturer you may be able to replace the screen. Best bet is to obtain the service manual first to see what is required for the task and see the stock order codes.
Oct 06, 2007 | Televison & Video
Tip
How to make your Notebook last longer
I have been repairing laptops ,PCs and car amplifiers for over 20years .I own Kips computer service and KIPS CUSTOM AUDIO .THIS TIP IS ABOUT HOW TO MAKE YOUR LAPTOP LAST LONGER.THE THREE MAIN THINGS THAT i SEE BROKEN ON LAPTOPS WHEN PEOPLE BRING THEM IN FOR REPAIR ARE.
#1 THE DC JACK THAT CONNECTS THE NOTEBOOK TO THE DC ADAPTER.These are usually broken from the user wrapping the cord around
the notebook when moving it from place to place.
They also get broken from being tripped on while the laptop sets on a table being used and someone walking by trips on the power cord.(If this problem Isnt Fixed it will eventual ruin the motherboard.
#2- The harddrives in laptops are very fragile moving the LT around from place to place while it is on will ruin the hard drive.
#3 Cracked screens common sence should tell you how to avoid this.
on Mar 10, 2010 | Computers & Internet
Why does Kodak Pix Pro show black screen after being lightly dropped?
Unfortunately, even lightly dropped can cause problems if it lands just the right way. For instance, at my work, I have dropped my smart phone numerous times, including onto bare pavement and never a problem. Another guy at work, knocks his off a 12" patio table and the screen shatters. It could be as simple as a knocked loose connector inside.
Jun 14, 2015 | Kodak Cameras
I have an ACER 5750z and it won't charge properly. It's getting worse and it's only 2 years old. I have to unplug constantly but it's very sensitive and if knocked, the charging goes off. Any help of...
For the most part; the jack where you insert the power supply has a defect, or the power cord plug-end that sits in the port is going bad. Check the power supply and if you can get one like it to test it on your computer; do that and see if that helps.
My customers that come in with the same problem as you describe; tell me they tripped over the cord, someone pulled on it from an angle, or physically bent it. Hope its just a bad power supply as this is not expensive to replace; the jack attached to the mainboard is a real problem to fix.
Sep 23, 2013 | Acer Aspire 5350 5750 5750g 5750z Series...
Touchscreen isn't working
A little more information would be advised.
is it cracked? shattered? Does it even light up?
Aug 02, 2013 | ZTE Cell Phones
Computer screen is not broken but no display and looks as though it has shattered
It sounds like the screen is broken, possibly from some kind of shock. Replacement screens are all over ebay and fairly easy to install. You can download the service manuals for any laptop via Google
Dec 05, 2009 | Computers & Internet
Screen is cracking while we are watching
The possibility is that the heat generated by your plasma screen tv is affecting the outer mask of the screen causing the cracks to appear .
Or it may be that the screen has been struck in some fashion and the cracks are a result , do you have small children this is often a cause as they tend to hit things and you are unaware ?. My advice to you is to seek engineers assistance as soon as possible . regards Vortash
May 11, 2009 | LG 42PX5D 42 in. Plasma HDTV
HELP!!!! - Vizio GV47LF LCD HDTV HELP!!! - HOW TO FIX?
When you turn it in, do you get an image? And if it is the LCD screen ( not the front protected glass) then yeah you might as well junk the TV. The cost for a replacement LCD screen exceed the cost of the unit. Sorry about the bad news, just being honest. Turn the television, if the LCD is cracked, then you will see it right away when the television is turned on.
Nov 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
